75 marinogelb swallowtail
(In Topic #206147)
Last edit: by scottyr1
The extra electrics sound like they might be for an engine heater or interior heater of some description. Its law in some parts of Scandinavia that you cannot leave a car idling for more than 5 minutes and with the cold mornings they get, a lot of people plug them into the mains over night.
scottyr1 said
Nice find mate, after seeing your cabby I know this will be amazing.
Yomp said
Good luck with it!
I think you may be right
mk1gti79 said
Best luck another beut saved well done fella mk1gti79
Thanks at
I'll look forwards to seeing the progress. It'll be amazing when it's done.
mike.d1979 said
I love the colour, you really have taken on quite a lot of work!
I'll look forwards to seeing the progress. It'll be amazing when it's done.![]()
As it's from Sweden, did it come with a set of studded winter tires?
It didn't Mike. Just came in a set of winters that aren't studded.
I also started to strip the interior a bit to see what i'm working with. So far it doesn't look too bad
The passenger rear arch has had a previous repair done to it, but the outer tub seems solid with a couple of small holes to the inner tub. The drivers side outer tub is starting to go and the inner seems solid on that side.
I managed to take a look inside the drivers door and found that the lower is starting to rot.
Heres the photos
Matt
Always fancied a yellow swallowtail to restore
From those pics it looks that the bodywork will keep you busy for a while
The main part of the rot is on the lower A pillar section and drivers side inner wing. I'm determined to get it sorted and haven't let it get me down. On the plus side, the floor is in good condition and pretty solid
Baggie82 said
So today the strip down happened to see how bad the car actually is.
Blimey that's looks like a some extensive bodywork restoration/fabrication will be needed.
Hats off to you for wanting to do this
Regards Volkswarren
volkswarren said
who is dipping it? and whats the cost roughly for a mk1?
Envirostrip are dipping it for me and is £895 without any primer. It costs £300 - £500 depending on what primer you want on it thought.
Irvs wants it left as is so he can sort any remaining bits of rust if there is any and then he will primer it himself.
