Heater Resistor needed asap!
(In Topic #148722)
Hello,
I need a heater blower resistor ASAP please, as mine has packed up (I think - the fan is fine…)
I'm in Reading/Slough so around there would be good, but I'm not adverse to p+p!
£15 posted including loom section
its cold
Hi mate,.should have given me ashout,got them about.
Hi I also need a heater blower resistor, where can I get one and how much will it cost please
heater
Well i've dug out two complete heater boxes,got one good working heater blower fan other fan is part seized.tested both resistors on working blower and they both work,tested um by hardwiring to12v supply on all three fan positive supplies to check 3 speeds of fan.
got the junglist collecting one resistor tonite so i'm left with one spare.
make sure you check all the wiring as its common that poor contact between wiring terminals can stop umm,live and earth on fan are common for bad contact,poor earth above fusebox,loom to resistor loom plugs burn out.check clean and pinch up all terminals.same for fan switch and its loom and positive supply from fusebox, a spare fan switch is good to.
hope this might help sum ov you out there.
any probs call me 0793 5454 384
heater
…£15 tested n working heater resistor posted.or collection wellcome,can fit for extra.
