abf engine mounts
(In Topic #150535)
mk1 1.3 to 2.0 16v abf
Im after the correct mounts for my conversion if anyone has them
In my opinion for the cost of them your best buying new ones mate, standard 8valve gti ones fit no problem, but I believe you'll have to move the drivers side bracket up the chassis leg (cut off an reweld).
Depends what gearbox your using? If your running a o2o box then you can use all stock mounts, on the driver side engine mount you can use a big block 8v mount.
justcaddys on ebay sell 02j cable change mounts if you go that way, buy the 20v set of three & sell the cam belt side 20v mount back on as you need a 8v big block cambelt side mount for the ABF,..Using your 1.1/1.3 mounting bracket off the chassis leg is ok but the slotted part of the bracket will sit at a angle instead of being parallel…..cheaper option tho,.. would advise to fit cable box, 020 box on a ABF don't last long plus you have to spend a small fortune on a clutch,….vr6 clutch/flywheel etc are two apenny or a sach's uprated one for an ABF,…Only down side is if using volkswagon donor VW abf gearbox is hydraulic clutch so you need a SEAT cable mech & cut down your 1.3 cable to suit.
plus cablebox is stronger, less gearchanges & great for a 5th gear conversion 160mph+
thanks for the help people.
Do any of you have any pictures?
