vw jetta
(In Topic #78869)
vw jetta
Jamo
first off, we've had lots of debate in past over the Jetta as we all thought a Golf with a boot but technically not! (I can't recall the exact reasons) Which is why we're MK1 Golf only!
Not saying you're not welcome but there is a Jetta web site/register from memory - hopefully someone here will know the link.
Anyway, from your description, do you mean the clutch cable is pulling through the bulkhead? If so you can get a stick on and weld on repair panel for this area. I've seen them on ebay but guess cheaper from places like www.perfectpanels.com
Hope you sort it!
Life Member
http://www.jettaownersclub.com/
You are more than welcome here though as of course the Golf and Jetta share many parts and were built in the same factory. Also that means they have common design faults and the clutch cable pulling through the bulkhead is a well know one on RHDs.
Happy posting
Rajan
Luv Chrissie xxx
Mk1's Rock \m/
same clutch,its only had 2 new pressure plates and 10 friction discs 8O
Bert
Life Member
On the original LHD cars this area was properly reinforced, however it is not as strong on RHD cars. You can get special panels to repair this area though.
As mentioned, we don't cater for Jetta's specifically, as there is an alternative club, however please feel free to browse and ask questions, as most of the mechanicals are identical.
Cheers,
Drew.
Once a Mk1 fan, always a Mk1 Fan...
