Golf GTI can or clipper with engine swap?
(In Topic #241875)
However it doesn't say GTI. On log book just Golf.
It has an injection engine though and not carb but a lot of things seem to have been modded on the car and not sure whether the engine could have been changed if the old one had broken etc
I know this has been covered before because I found some old posts. I have checked the data sticker in the boot
And can't work out whether it's a DX or EX as it isn't very clear and worn and mouldy!
I can post pics of the data sticker and of the car 👍
(I think it's a D but it's really hard to tell )
I'm just wondering if there is any other way to tell definitively
And what I should look for?
I appreciate anyone who has some advice/ ideas
And thanks fin advance for any help x
it’s been years since I looked at my log book but does it not have the engine code on the log book?
mark1gls said
Do you have the MFA computer in the instrument cluster?
Hi mark
Thanks for the reply
I will check but don't think so
Also I don't know what the MFA computer is or what it looks like sorry 🤦♂️
This is the first time I have owned one
If you tell me what it looks like I can check 👍
Regarding MFA, do you have a button on the end of the wash/wipe stalk?
Amongst other components, your cylinder head will have a casting date on it (towards its front right hand side, above the coolant flange, as you look into the engine bay), the date on it should in theory be slightly earlier… 5th June 1983 in the example below
If it post-dates the cars build date, it might be an indicator it's been changed.
If it pre-dates the cars and by some margin it may also indicate a change.
if it's close, it potentially may be the original.
Is your engine number not visible on the block itself?
paceman said
Yeah, the V5 should have the engine number on it, but if it has been swapped, and done properly, the engine number will have been changed on the v5. You might need to pay for a car check (or whatever it's called, used to be HPI check) as that will show any changes to the v5 over the years.
Yes it does have a button on the stalk 👍
Is that good? 🙏👍🤣
I can't work out how to pay pics on a reply 🤦♂️
Last edit: by Noclue
Is that good? 🙏👍🤣
And thanks for your time 👍
bacardincoke said
Hard to make out from the image, so subject to my having read it correctly, your cars build date works out around 12th April 1989 (give or take a day or two, depending on which guide you use).
Hello sorry to be a bit thick
Is it two numbers on the outside circle? As mine says 8 8
Where the pic you sent says 8 3
I can't work out how to post a photo of it in the reply
Thanks for the advice
Think I've worked out how to add an image that's mine
Best I could get before the rain!!
If it's 88 does that tie in with it being registered in 1989?
Cheers for you help
The day of the month is shown by a combination of which of the four digits pointed to by the triangular marker 0, 1, 2, 3 along with which of the numbers are beside it on the inner wheel, they are 0 up to 9
In the photo's case it is 0 beside 5, so the 5th.
The central part will show the month, 6 (for June) in the photo, it could be any number from of 1 to 12.
Let me know what you think
And thanks a lot 👍
I will have a look tomorrow for those other numbers!
as it's raining in sunny wales 🤦♂️
I will try and get some better pics of both and will report back
The more I look at the sticker in the boot the more I think it looks like a Dx as there are 2 distinct vertical lines on the first character which would indicate GTI
But it's hard to tell for sure
At least you're on the right side of things date wise.
If it'd been for example a 1990 head I'd have speculated it could have maybe been a later replacement.
I can't comment on whether or not it being over a year older than the cars manufacturing date is potentially possible.
I can only say that of the three engines I've here, all the heads were only cast a month or two before the cars they're in were manufactured.
Perhaps others can give examples and we can get a better picture of what would've been normal.
Other engine ancilliaries will be date marked too, if they're collectively coming in around the same period it'd help support they started life together / original to your car.
Is that a thermo-time switch on the water flange in your image, the brass sensor with the brown plug?
Your car's running K-Jet?
Most of the Bosch K-Jet parts are date marked, if you can confirm the type of injection before I rabbit on more, I should be able to date them for you.
The intake manifolds casting date may be on it's forward facing visible surface.
The example below is week 27 of 1983.
I put a pic on earlier of what I think is the mfa and dash it has a button on the stalk is that it 👍
bacardincoke said
Maybe an easier one to see, before we get too deep.
The intake manifolds casting date may be on its forward facing visible surface.
I will upload a pic of the engine I took earlier
I have no idea what a k jet is
Maybe you can tell me 👍
I will put a pic on the thread
Cheers mate
I'm not familiar with Cabriolets and they may well have differences to the hatchbacks that I'm not aware of, there's plenty on the forum who will be able to help you better with those aspects of your car.
If I was standing in front of your engine it'd be the work of 10 minutes to identify the manufacturing dates of the main K-jet components, but at a distance and using images that's not going to be so easy.
It would've helped build up a better picture of your engine and its ancilliaries to make an educated guess as to whether or not they are original to your actual car or even a similarly aged / specced vehicle.
Unfortunately there's plenty of scope for one or more previous owners to have mixed and match parts, even down to the fundamentals like the block and / or head.
Your engine block will have the engine number stamped on it, it's in the same area and below where the heads date casting wheel was.
If it's still legible you should be able to see what type (DX for example) it is, plus its number.
This is an image from another thread to help you locate it.
Regional Host NE
nicci21paul said
you got the reg number mate
Yes should I put it on here or msg you?
Cheers 👍
bacardincoke said
If your 88 is where the 83 is in that image then that'd indicate 1988
The plot thickens🤣
The log book turned up today and it says it was first registered in the uk
1/3/89
A month before it was made ?? 🤷♂️🤣
Regional Host NE
