Newbie 88' clipper cabriolet
(In Topic #205243)
Hi everyone.
been on vw scene since I was 6
owned too many cars.
normaly have air cooled vw's but fancied something fun to go work in.
Bought a 1988 golf clipper last month and love it.
having a few running issues but sure someone on here will know the problem/solution
live in kent (South east)
Welcome! I'm no mechanic but my first thought with clipper carbs and running issues, after the basics, are usually to do with the standard pierburg carb which is known to be problematic and often changed for a weber version, or fuel filler/tank/lines getting clogged with rust and debris over the years.
Compulsive buyer of knackered VWs!!!
Previous rides;
'81 Mk1 1100 C
'83 Mk1 1.8 GTI
'93 Corrado 16v 9A
'81 Mk1 GLI cab
'91 Mk2 16v KR
'89 T3 Whitestar
'87 T3 Caravelle GL
'95 Polo G40 LHD
'93 Mk1 Sportline LHD
Previous rides;
'81 Mk1 1100 C
'83 Mk1 1.8 GTI
'93 Corrado 16v 9A
'81 Mk1 GLI cab
'91 Mk2 16v KR
'89 T3 Whitestar
'87 T3 Caravelle GL
'95 Polo G40 LHD
have the fuel injection engine fitted
so may be something to do with that.
has had a new lift pump and fuel filter within the last year.
Looks like fuel filler pipe has a small amount of corrosion could be that.
but gets better when warm the judder
Sounds like fuel pipe rust issue. Change fuel filler pipe and then give tank a good clean check condition by removing fuel pump. And magnets. Change tank if any doubt. Then give all fuel lines an air blow to upto filter.then change filter (hopefully doing job )and collecting the waste/rust. Very common issue and 1 I suspect I'm beginning to have again on one of my cars.
On the drive
Myvalver 89 GTi Grey mk2 16v
hi mate
welcome too.
Take a look in the engines section and the google search box is really good too it's on the left hand side of the site, just scroll to you find it..
chortle
welcome too.
chortle
