New from across the Pond.
Hello,
My name is Briano, I am a TRF, Vortex, and VOC club member from the US.
I was looking at a linked topic, and discovered that some one mentioned my name, I think it was in a good way.
Well I have been driving a Rabbit/Golf since 1980 off the showroom, 1981 4 Door Alpine Green, Diesel LS… had over 480Kilometers
on it when I sold it 20 year later, and it still had the original axles on it.  :)  Yes they groaned on turns.
I am now in to US 90 Cabriolets, and have written a few how do you do that's.  While they are based on the 90 MK1, a lot is still applicable….
So here they are, have a great year.
Convertible Top
Top frame Seals:
http://volkswagenownersclub.com/vw/showthread.php/80306-Convertible-Top-Frame-Seals?p=605050#post605050
Replacing your Top, that pesky rear cable.
http://volkswagenownersclub.com/vw/showthread.php/89706-Replacing-your-top-that-pesky-rear-cable.?p=638234#post638234
Rear Cable that I can endorse.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=3012
Rear Cable Lubricant for Cloth tops.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=3208
How I install convertible tops.
http://volkswagenownersclub.com/vw/showthread.php/32262-Cabriolet-Convertible-Top-Installation
Installing your top padding kit.
http://volkswagenownersclub.com/vw/showthread.php/32182-Cabriolet-Top-Pad-Installation
Installing your head liner.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=3013
Replacing your rear window.
http://volkswagenownersclub.com/vw/showthread.php/57770-Cabriolet-Rear-Window-Replacement.?p=519466#post519466
How to make your own rain gutters.
http://volkswagenownersclub.com/vw/showthread.php/32177-Make-your-own-Vert-rain-gutters
"A" pillar gap repair.
http://volkswagenownersclub.com/vw/showthread.php/32474-Cabriolet-quot-A-quot-pillar-repair-the-Gap.
How to clean your "A" pillar seal.
http://volkswagenownersclub.com/vw/showthread.php/32218-Cabriolet-How-to-clean-your-quot-A-quot-pillar-Seal
Cabriolet top pad measurements.
http://volkswagenownersclub.com/vw/showthread.php/32194-Cabriolet-Top-Pad-Measurements
Ez-on top replacement instructions.
http://volkswagenownersclub.com/vw/showthread.php/32193-EZ-on-Cabriolet-Top-Installation
"A" pillar door seal repair, stop the drip.
http://volkswagenownersclub.com/vw/showthread.php/32192-Cabriolet-quot-A-quot-Pillar-Door-Seal
Where to oil your top frame.
http://volkswagenownersclub.com/vw/showthread.php/32191-Cabriolet-Top-Frame-Oil-Points
Cheaper replacement top struts.
http://volkswagenownersclub.com/vw/showthread.php/32190-Cabriolet-Cheaper-Top-Strut-Replacements
Top latch removal
http://volkswagenownersclub.com/vw/showthread.php/32189-Cabriolet-Top-Latch-removal
Make your own rear cable.
http://volkswagenownersclub.com/vw/showthread.php/32181-Cabriolet-DIY-rear-cable
Improve and make your own side tension cables.
http://volkswagenownersclub.com/vw/showthread.php/32180-Cabriolet-DIY-side-tension-cables
Electrical/Educational
Educational:
Inside of a fuse box
http://forums.vwvortex.com/showthread.php?7041478-Ever-Look-inside-a-fuse-box
Definitive Radiator fan operation explained:
http://volkswagenownersclub.com/vw/showthread.php/54346-Radiator-Fan-operation-explained-
Basic Electrical Tools for most common Repairs/Diagnosis.
http://www.toplessrabbit.com/forums/viewtopic.php?f=7&t=3211
Improving your grounds 93 digi.
http://forums.vwvortex.com/showthread.php?5284503-Ground-effects-and-the-repair-of-your-car
Improving your cluster grounds.
http://volkswagenownersclub.com/vw/showthread.php/24949-Improving-your-Cluster-Connections-and-ground.
Electrical Primer
http://volkswagenownersclub.com/vw/showthread.php/32254-Electric-Primer
Parasitic Drain Video
http://volkswagenownersclub.com/vw/showthread.php/32228-Parasitic-Drain-Video
Electrical:
Repairing your Fuel Sending unit.
http://volkswagenownersclub.com/vw/showthread.php/78890-Repairing-your-Fuel-Sending-Unit?p=600458#post600458
Headlight/Marker light out with Key out.
http://forums.vwvortex.com/showthread.php?7130550-Head-Light-Marker-lights-off-with-Key-out-fix
Repairing Mylar runs to the 10V Stabilizer. (Or Backfeeding the Voltages to the gauges.
http://volkswagenownersclub.com/vw/showthread.php/60258-90ish-Cabriolet-Mylar-repair-for-10v-stabilizer.?p=531266#post531266
Replacing the Ignition Switch in 90is Cabriolets.
http://volkswagenownersclub.com/vw/showthread.php/58418-Replacing-the-Ignition-switch-90ish-Cabriolet.?p=588594#post588594
How to remove your automatic starter.
http://volkswagenownersclub.com/vw/showthread.php/32183-Automatic-Starter-Removal-Install
My Wipers work, but the washer don't.
http://volkswagenownersclub.com/vw/showthread.php/32220-My-wipers-work-but-the-Washers-don-t.
Relaying your headlights.
http://volkswagenownersclub.com/vw/showthread.php/32215-Relaying-your-Head-Lights
Installing a a/c cut-out switch.
http://volkswagenownersclub.com/vw/showthread.php/32214-Installing-a-AC-compressor-Cut-out-Switch
Repairing your flaky water temp gauge.
http://volkswagenownersclub.com/vw/showthread.php/32211-Repairing-your-Flaky-Water-Temp-Gauge
Removing your non-york Alternator
http://volkswagenownersclub.com/vw/showthread.php/32210-Cabriolet-Alternator-Removal-Non-York-A-C
Cabriolet Bulb replacement numbers
http://volkswagenownersclub.com/vw/showthread.php/32209-Cabriolet-Bulb-Replacement-numbers
1985-1993 Radio Wiring pairs
http://volkswagenownersclub.com/vw/showthread.php/32206-1985-1993-Cabriolet-Radio-Wiring-Pairs.
1990-1993 Automatic no crank warm or cold
http://volkswagenownersclub.com/vw/showthread.php/32204-90-93-Automatic-No-Crank-Hot-or-Cold
1990-1993 Testing your Water temp gauge
http://volkswagenownersclub.com/vw/showthread.php/32195-Testing-Digifant-Water-Gauge
The smarter fuse:
http://volkswagenownersclub.com/vw/showthread.php/32185-Smarter-Fuses...-Glows-when-blows.
Repair your rear window defroster lines:
http://toplessrabbit.com/forums/posting.php?mode=edit&f=7&p=17634
Engine/cooling:
Leaky Heater Valve, and beefing it up.
http://volkswagenownersclub.com/vw/showthread.php/91714-Those-Plastic-Heater-Valves.....?p=644178#post644178
Swapping in a 2.0L 36mm Oil pump. Heads up.http://www.toplessrabbit.com/forums/viewtopic.php?f=6&t=3232
How I hate plastic parts:
http://forums.vwvortex.com/showthread.php?6907318-I-still-hate-plastic-parts-but-thanks-Tolusina&highlight=hate+plastic+parts
How I converted from r12 with r134a:
http://volkswagenownersclub.com/vw/showthread.php/10057-How-I-converted-my-a-c-to-r134a
Definitive Radiator Fan Circuits explained:
http://volkswagenownersclub.com/vw/showthread.php/54346-Radiator-Fan-operation-explained-%29?p=504978#post504978
How to flush your radiator:
http://volkswagenownersclub.com/vw/showthread.php/21399-How-to-flush-your-radiator
How to replace your Valve cover gasket 1990-1993
http://volkswagenownersclub.com/vw/showthread.php/24508-How-to-Replace-your-Valve-Cover-Gasket.-90-93-Cabby.
How to change your water pump 1990-1993 Cabriolet
http://volkswagenownersclub.com/vw/showthread.php/21830-How-I-change-out-my-Water-Pump
How to tighten a squealing a/c belt.
http://volkswagenownersclub.com/vw/showthread.php/32219-Cabriolet-Tighten-Squeeling-a-c-Belt
Triming your Radiator Shroud easy on/off.
http://volkswagenownersclub.com/vw/showthread.php/32213-Triming-your-Radiator-Shroud
How to change your in-tank fuel pump 1984.5-1993.
http://volkswagenownersclub.com/vw/showthread.php/32212-1984.5-1993-mk1-How-to-change-your-in-tank-fuel-pump
Additions to Ron's Digifant Single Fuel Pump Conversion.
http://forums.vwvortex.com/showthread.php?5519363-A-VERY-big-thank-you-to-Tolusina&highlight=big+thank+you+Tolusina
How I change the plug wires.
http://volkswagenownersclub.com/vw/showthread.php/32208-How-to-Change-your-Plugs-and-Wires-Digifant.
How to install a external oil cooler.
http://volkswagenownersclub.com/vw/showthread.php/32200-Installing-an-External-Oil-Cooler
Digifant Intake tube repair.
http://volkswagenownersclub.com/vw/showthread.php/32188-Digifant-Air-Intake-Tube-Repair
Create your own dual down pipe:
http://volkswagenownersclub.com/vw/showthread.php/32179-Create-your-own-dual-down-pipe-1.8
Exterior:
Leaky Car Syndrome fixes:
Another Leaky Knee Fix.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=2737
Swimming Pool in Front Seats.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=2853
Where is my top leaking.
http://www.toplessrabbit.com/forums/viewtopic.php?f=41&t=2655
Where is my trunk leaking.
http://volkswagenownersclub.com/vw/showthread.php/32207-Cabriolet-mk1-Where-is-my-Trunk-Leaking
How to un-bolt pivot windows hardware.
http://forums.vwvortex.com/showthread.php?7199576-Vent-window-latch-swap&p=87874731#post87874731
Where Do I Place Jack Stands
http://forums.vwvortex.com/showthread.php?7122160-Jack-Stands-under-Cabriolet&p=87189221#post87189221
How I clean my Cabriolet.
http://volkswagenownersclub.com/vw/showthread.php/10022-How-I-clean-my-Mk1
Removing your Flag Mirror Glass
http://forums.vwvortex.com/showthread.php?7068757-Ever-want-to-take-the-mirror-glass-out-of-your-flag-mirror&p=86622489#post86622489
Repair your broken Grill Tabs
http://forums.vwvortex.com/showthread.php?6981782-Broken-Grill-Tabs
Installing Front windshield videos
http://volkswagenownersclub.com/vw/showthread.php/32710-Installing-MK1-Windshield-Videos
Saggy door fix.
http://volkswagenownersclub.com/vw/showthread.php/32222-Saggy-Door-Fix
Hood Vent Debris Guard, Let's keep those rain drains clean.
http://www.toplessrabbit.com/forums/viewtopic.php?f=27&t=1509&p=27750#p27750
Factory Paint in a rattle can
http://volkswagenownersclub.com/vw/showthread.php/32221-Factory-paint-in-a-Rattle-Can.
Repair a broken grille mount.
http://volkswagenownersclub.com/vw/showthread.php/32223-How-to-repair-a-broken-Grille-mount.
Using a non-powered door in a 1990-1993 Cabriolet
http://volkswagenownersclub.com/vw/showthread.php/32199-How-to-use-a-non-Powered-window-door-in-a-later-Cabriolet
How to make a debris guard for the hood.
http://volkswagenownersclub.com/vw/showthread.php/32217-How-to-make-a-Hood-Debris-Guard
How to remove and regrease your door latches.
http://volkswagenownersclub.com/vw/showthread.php/32216-How-to-remove-and-re-grease-your-Door-Latches
How to gold leaf your badges.
http://volkswagenownersclub.com/vw/showthread.php/32198-Gold-Leafing-your-Badges
How to remove your inner lights on a quad grille:
http://volkswagenownersclub.com/vw/showthread.php/32186-Cabriolet-or-Quad-Grille-Hi-Beam-Removal
Interior:
Every Vent fix I have ever thought of.
http://volkswagenownersclub.com/vw/showthread.php/9898-Cold-Hands%5C-Whistleing-Vents
Cold hand whistling vents.
Rear seat back pull replacement.
http://volkswagenownersclub.com/vw/showthread.php/32227-Seat-Back-Release-Pull-Replacement.
Making a Parcel Shelf.
http://volkswagenownersclub.com/vw/showthread.php/33293-Remaking-your-Cabriolet-Parcel-Shelf.
Cabriolet Trunk Lid Key Lock cover.
http://www.toplessrabbit.com/forums/viewtopic.php?f=29&t=3198&p=27535#p27535
How to remove a door card and adjust the window and stop.
http://volkswagenownersclub.com/vw/showthread.php/32226-How-to-remove-door-card-and-adjust-window-stop
How to repair broken trunk card board.
http://volkswagenownersclub.com/vw/showthread.php/32225-Cabriolet-Repair-Trunk-Cardboard.
Where is my trunk leaking:
2-door/Cabriolet seat back release cable repair.
http://volkswagenownersclub.com/vw/showthread.php/32205-2-Door%5CCabriolet-Seat-Back-Cable-Replacement
Floppy vent fix.
http://volkswagenownersclub.com/vw/showthread.php/32203-How-to-repair-floppy-vents
Repair your Heater control pivot.
http://volkswagenownersclub.com/vw/showthread.php/46441-My-heater-control-pivot-broke-%28Cabriolet%29
A/C thermoswitch Slider pops out of the Arm.
http://volkswagenownersclub.com/vw/showthread.php/74489-A-C-slider-pops-out-of-place.?p=584825#post584825
Repair a broken heater control mount.
http://volkswagenownersclub.com/vw/showthread.php/52938-Repair-a-broken-heater-control-mount.-Cabriolet
Replace your chewed roll bar foam
http://volkswagenownersclub.com/vw/showthread.php/32202-Cabriolet-How-to-Replace-your-Chewed-Roll-Bar-Foam
Seat rocks and is hard to slide.
http://volkswagenownersclub.com/vw/showthread.php/32197-Cabriolet-Rabbit-Seat-rocks-and-hard-to-slide
Cabriolet Fascia mounts broke?
http://volkswagenownersclub.com/vw/showthread.php/32187-Cabriolet-Fascia-Mount-hole-repair
How to safely remove your center and side vents.
http://volkswagenownersclub.com/vw/showthread.php/32184-Cabriolet-Caddy-Center-Vent-Removal
How to replace your slow seat belt retractors.
http://volkswagenownersclub.com/vw/showthread.php/32178-Replacing-Slow-Seat-Belts-in-Cabriolet
Suspension/Steering:
Broken sway bar strap fix.
http://forums.vwvortex.com/showthread.php?7551537-Broken-Sway-bar-Strap-%28cabriolets%29-fix
How to replace your rear struts:
http://volkswagenownersclub.com/vw/showthread.php/32174-How-to-replace-your-Rear-Struts
How to replace bushings with no press.
http://volkswagenownersclub.com/vw/showthread.php/32169-How-to-Press-in-Control-Arm-Bushings-without-a-Press.
How to replace your front struts, and mounts.
http://volkswagenownersclub.com/vw/showthread.php/32171-Replacing-Front-Struts-and-Mounts
How to keep the rear lower shock bolt from seizing.
http://volkswagenownersclub.com/vw/showthread.php/32172-How-to-Keep-Rear-Lower-Strut-Bolt-from-Seizing.
How to remove a power steering pump.
http://volkswagenownersclub.com/vw/showthread.php/32173-How-to-remove-a-Mk1-Power-Steering-Pump
Transmission:
How to remove and replace a torque convertor seal.
http://volkswagenownersclub.com/vw/showthread.php/32224-Remove-and-replace-Torque-Convertor-Seal-010-transmission.
How to change a differential seal:
http://volkswagenownersclub.com/vw/showthread.php/32196-Changing-a-Differential-Seal
How to make a cheap weighted shift rod.
http://volkswagenownersclub.com/vw/showthread.php/32201-Cheap-Weighted-Shifter-Rod
Automatic Transmisison Service guide.
http://reflectionsandshadows.com/a1-tech/BIGATSG.pdf
Wow and Welcome to the Club!  :thumbs:
Hey!
Cheers for that, should keep me busy for a while! lol
Welcome to the club!
Welcome…. Some very helpful links which will be alot of use, thanks for posting them.  :thumbs:
Must admit I've only read three of them so far but I've been very impressed.  :)
Thank you so much for sharing with us all!  :thumbs:
Excellent resource there. Thanks. Oh, and welcome
Just a who am I?
My first car was a 58 AH Sprite, I totally bought it at age of 13, for 50 dollars, and it ran back in 1971.  I dissasembled it, and started to gather parts for it, I had the engine bored, new pistons, and wouldn't you know came across a 67 MG Midget for 250, when I was only 15… Totally rebuilt that engine, tranny, suspension, (Armstrong lever action shocks) with my Fathers assistance, and drove it like I was at Lemans….1100CC of fun…. Taught me Mechanics, and that you guys valued heaters as an dealer installed add-on (yep have the original window sticker)…. Even in cold Illinois, the heater wasn't the Greatest….
The 58 was put on hold, and remains to this day, with the body work done, new wiring harness, Engine ready to be built, Tranny overhauled, all the various bits and pieces in boxes and bags, polished waxed and coated with Cosmoline… sitting in a barn in Illinois….for over40 years… I will get to it one day….Funny how life interrupts plans…
The last car of my youth was a 72 Rover 3500S that I bought in 74 for 1400…. It was a nice ride… Champion Spark plugs paid for a engine rebuild (because of defective plugs, getting ingested in to 2 opposing Cylinders) and I had Borg Warner rebuild the tranny for free…(helps to know folks).
I have wrenched rebuilt and repaired all my auto's and got in to Rabbits/Golfs in 1980 when I needed a car with good mileage, So I drove a 81 Diesel LS off the showroom, green/tan….. put well over 300K miles on it prior to sell it in 2000.
Had some Physical issues and kiddies didn't want a diesel…. So 4 years later I bought my first Cabriolet, Triple white, replaced the clutch, top, put a header, short shifter, and got 42mph on the highway @ 75 mph… As I had the shop lined up to paint it, I got rear ended,,, totaled… didn't cry, they gave me 4 times what I had paid for it.
So being the fool I bought 2 more in 8 months, and currently drive them both, well a daughter drives one, and I drive the other.   I have replaced and repaired a lot of things but here they are for your perusal.
Yep both are automatics….. Nope I am not ever going to swap them out.
A couple of tidy cars you have there.
I see you have power steering and is that digifant fuel injection and I guess you have a CAT fitted?
You seem to have more pipes and sensors I'm used to on my 88 GTi.
Yes, I have Power Steering, Power Windows, and the Knee-Bar from Hades.  I have converted from a Single Down Pipe to Dual Down, and I have a CAT, which I put on for emissions, get inspected, remove and install on the other cabby, get inspected, and removed… :)  I only have but 1 more inspection on one, and 2 on the other before they pass the 25 year mark, and I have a Cat Delete SS header that will be putting on.. Can't wait.
Sensors are not the issue it is those plastic outlet flanges, and fitting on the cooling system that has been a PITA.
But I have figured out how to replace them with parts off a 84 Golf/Cabriolet so I don't have to replace them any more as it was a yearly thing… See my link above to I HATE Plastic Parts.
Thanks for the complements, I do get winks and nods from folks in the parking lots of stores, and I get really big smiles when I use the thing for Hauling Plywood, and Lumber…
It may not be the fastest thing but I can go from 0-topless in 2 seconds flat… :)
Wow thanks for sharing all the links - great resource there.  :thumbs:
Nice engine bays too…  :cool:
Your scuttle panel (rain tray) seems a bit different to our too - your looks longer. Where are your vin plates located? Our are on the front panel…
Cheers Hugh.
Shughy said
Wow thanks for sharing all the links - great resource there.  :thumbs:Nice engine bays too…  :cool:Your scuttle panel (rain tray) seems a bit different to our too - your looks longer. Where are your vin plates located? Our are on the front panel…
Thank you…
That is because I have A/C on both cars, (Yes it works really really good.).  The Vin's are in 3 places.
The ZZZZ one that is the build is on the rain tray.
There is one on the "B" pillar sill of the Drivers door, and then the plate on the Dash.
I have gotten 2nd place in shows, but that was a few years ago, every year when it is show time something comes up…so I can't go…but then there is always next year….
But A/C in Georgia where the street temps can hit well over 100, as in the summer does come in really handy, seen the street temp on my van hit 130….
