registered at last but still not an owner
(In Topic #76703)
I'm now after an upgrade for the driver in the shape of a campaign gti. Is this a sensible move? I will need it to be my regular daily drive (shopping, IKEA trips, commuting, etc.) and it'll be parked outside year round. So it needs to be robust, reliable and self-sufficient (and water tight of course).
I plan to do any maintenance work myself, I'm very familiar with mk2 mechanics and have experience of k-jet from an old 911 I used to own so I'd hope to not be too suprised by a mk1 gti. Plus this site is invaluable too…
All opinions welcome but specifically, opinions on motorway miles in a mk1 (how comfortable?) and modifications. At the moment I'd be putting an uprated headlight loom in (direct swap from my mk2) and an electric wing mirror loom in too (again from my mk2)
plus part compatability, obvioulsy all my old carb parts and trim parts can go in the bin but what parts might be intercahngeable with my mk2 spares collection (things like CV joints, brake parts, suspension top mounts, clutch parts)
many thanks in advance
another Drew
Hope you enjoy your soon to have MK1!
My advice if you're after a daily ride is don't have to go for a Campaign model. Se this thread http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=6777 on current debate between Campaign model and late series 2 MK1 Gti's. (also check our guides for 'Campaign checks) You will normally pay a premium for buying a Campaign and for a daily drive you may want to broaden your choice a bit.
Mine has been a daily driver - top tip is spend as much as you can on the car rather than go cheap and save for spares. You should be able to get a very good original or previously restored MK1 Gti for the ?1500-?2500 bracket, depending how lucky you are as some bargains to be had now and again!
Worth doing the headlight upgrade but IMO wouldn't worry about electric mirrors, you can reach both from the drivers seat and only something else to do wrong!
Keep us posted, ask any questions you have and show us some pics when you've bought one!!
The other bits, leather steering wheels, sunroof, having EW written in the engine bay, etc. are less important.
questions:
which mk1s came with rear disc brakes as standard.
did any mk1 come with 239mm vented front discs as standard (ie mk2 size)
I read that the campaign model came with a slightly different engine (cam profile) and a slightly taller 5spd box than the late series 2 car. Is this correct?
how likely is a sunroof to leak (ie should I actively avoid sunroofs)?
To answer your list of questions;
1. None had rear discs as standard
2. Again no, I believe all were same size
3. Not as far as I'm aware - defo same 1.8 engine, ref the box the Campaign had a 9A box which I think was the same on the non-Campaign 1.8 Gti's. 1.6 Gti boxes were different ratios I think as I've heard people talking about swapping
4. If it's rusty, it will probably leak!! A lot is personal opinion as many wont buy a MK1 with a sunroof. Personally, I really like them - it's like anything, check it for rust - esp. in the drain tubes. If no rust, chances are it wont leak!
Hope the above helps (and is all correct!) but I will soon be corrected if any of this is wrong!
Just get the most solid, 1.8 Gti you can, be it Campaign or not. You can try people like Wagen Wheels in Southampton http://www.wagenwheels.co.uk/cars_for_sale.htm but you will obviously pay a premium over a private sale but at least have some come-back.
What sort of budget are you lookin to spend?
The 5 speed box and 1.8 engine (DX engine code) are not exclusive to the Campaign. The engine was first fitted to the GTI in 1982 and the 5 speed box was standard from 80/81. No mk1 (even GTI) came with rear disc brakes as standard. The GTI came with 239 mm vented front discs as standard.
From what I understand the cam profile is the same on Campaign and non-Campign 1.8 DX engines fitted to mk1s. Its profile was changed when the DX engine was fitted to the mk2. My understanding is that the mk2 had a taller box than the mk1, but that the Campaign has a slightly taller box than the non-campaign 1.8 GTI.
Factory fit sunroof (which were only ever sliding steel panels) should not leak if looked after and well maintained. Opening the sunroof up should immediately highlight any rust marks or bubbling around the sunroof aperture. Stay away from glass sunroofs (these can leak badly, may be made by a defunct manufacturer and effect the value of the car). You will also find the occasional mk1 with a Webasto sunroof. These can also be leaky and are non-standard.
From what you say you should be looking for a Yreg 1.8 5 speed mk1 GTI. These can be found with or without steel sunroofs and come with trip computers as standard.
Good luck with your search.
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
The taller box ratios are important to me as I'd like to be good on a motorway run as well as on roundabouts :wink: . So budget permitting I'm still looking for a campaign model.
plus leccy windows. I've found an EW car with window handles. Would this be original?
anyway, thanks for all the help guys. I'm looking at a few cars over the next couple of days so I'll keep you posted
1983 1100 C
1983 1100 C
Ref daily driver, any 1.8 5-speed will be a good motorway cruiser, my Campaign will happily keep up with modern traffic (and surpass it sometimes even! :wink: ) My only niggle with mine is the drivers seat is a little saggy but aside from this I've done 200-300 mile trips with no worries, taken it on holiday…..
1991 MK2 Golf G60 20VT
1991 MK2 Golf GTI 16V Oak Green
www.vwgolfmk2.co.uk
www.vwgolfmk2.co.uk
