Petrol flow
(In Topic #226059)
It also list 171919051L but a quick search on the web shows the sender with no out lets?
Might be worth dropping them an email to check?
https://www.classic-vw.co.uk/fuel-level-sender-171919051l-vdo-mk1-golf-scirocco-jetta-14122-p.asp
Sorry can't be much more help…
I know it's easy to say after the event but hitting the sender with a hammer to remove it is not the way to go when they are old plastic items, making a tool from a cross section of wood which slots in is a better way to remove them.
The pic I used is later metal version, think the eariler plastic version is obsolete
mark1gls said
I thought the early versions where metal and later version was plastic like alot of stuff VW fitted to later cars to keep cost down like all the flanges and water pump housing in the engine bay, even the oil filler cap went from metal to plastic…..![]()
Not sure, the cars I've worked on the sender have all been S2 80-83 and had plastic fittings so assumed (never a good idea) the metal ones were later, esp with the later larger cabrio tank change.
Find a better mechanic or do it DIY before he damages something even more expensive! And definitely don't pay him a single penny.
DaveFMk1 said
Thanks all finding it great that there are a few of you who take the time to help out a new boy. I will be visiting the garage in the morning to work out how he can get this fixed as he described the part as small for about a fiver originally yet I sent the link from mark1gls above and mechanic agrees it's the right part but it's 55 quid so we are 50 quid out!!! 😢 He has fixed other stuff and when this is sorted i won't return as have found another mechanic who loves Mk1s so if I have anything else I will go there - thanks again all very kind
Its not the same, its only the sender for the gauge for injection and Diesel models that take the fuel from an outlet at the bottom of the tank. The one you want has the sender for the gauge and the feed and return fuel line connections too
https://www.classic-vw.co.uk/fuel-level-sender-171919051l-classic-line-mk1-golf-scirocco-jetta-20968-p.asp
https://www.eurocarparts.com/p/siemens-vdo-fuel-level-sender-unit-468440030
DaveFMk1 said
Sorry also found this link i can collect on Friday - thoughts ?
That looks like just the sender again. You need one with the pipe that goes into the tank to connect to the feed to the fuel pump and a connection to the return from the carb.
https://www.ebay.co.uk/itm/Mk1-Golf-Fuel-Tank/193431321338?hash=item2d0967bafa%3Ag%3AX58AAOSw4A9enaMy&LH_ItemCondition=4
DaveFMk1 said
Yes wrong part from EuroParts so back to square one as do need one with pipe with 2 pipes coming out of it - any ideas where I can buy whole unit
Lots of googling to find someone in Latvia with NOS (new old stock) one and wants your kidney for payment, or something used from fleabay like the link I posted.
