New guy here
(In Topic #119774)
New guy here
Im looking for something that needs some work doing as a bit of a project and ive just started shift work so need something to do in my time off whilst my mates are all stuck in work. Im hopeing i can find out all i need here.
diesels do pop up occasionally but theyre quite rare. Will probably be easier to find a decent small block petrol.
Good luck with the search and post some pictures up when you find "the one"!
as rossirvine said diesels & even turbo diesel mk1's are about but, rare.
most mk1's are fairly cheap to run & maintain, because they have simple mechicanics/etc…
good luck with your search, & might see you about, if your local too St.Albans?
If you do find a diesel it will probably be a wreck in need of major repair as they were rarer to start with and abused more than the rest, but if it's a project you want then that would suit you?
Like the others said, if you're not dead set on a diesel though, the petrol ones are a lot easier to find, and there's loads in good condition. A 5 door small block petrol you're most likely to find would be a late 1.3 'CL' or 1.1 'C Formel E'. There are more 5 door models in the big block range. Let us know how you get on.
am i being unrealistic in hoping to pau about £300-£400 for one that needs some tidying up doing?
hope you find what your looking for, the search is always pain staking but worth it :wink:
GOLF MKII GTI 8V - sold
GOLF MKII DRIVER - ex took it
GOLF MKII GTI 16V - scrapped
JETTA MkII GTI 8V LMT EDTION
