MK1 GOLF GTI RIVAGE
(In Topic #128995)
MK1 GOLF GTI RIVAGE
MK1 GOLF GTI Rivage | Flickr -pics of my beauty
He's not that new to me, almost had a year, love it more then ever but got major leaks in the footwells…can anyone help me??
thanks
emma
thanks
emma
Hi Emma, check underbonnet, really close to the windscreen that your drainage channels and gromets arnt blocked. There are some rubber gromet type things underneath there that channel all the rain water away, they can some times get blocked which may force water into cabin, also check door / window seals
Rich :-)
Rich :-)
1.8T CABBY
1.8T CABBY
thanks rich!
ive just checked. the driver side was slightly clogged, but the passenger side where the problem is was also clogged but also has wiring going though the gromit, so doesnt leave much space for when heavy rain to pour through! is this normal? do i need to get my wiring looked at to run through somewhere else?
thanks
m
thanks
m
Hiya and welcome to the site!!! Rich looks to be pointing you in the right direction.
Welcome, good choice of car by the way.. Can't you just not get it wet?.. Ever?.. That would help.. I have no idea whatsoever if mine leaks.. :mrgreen:
em as i said in pm
it could be a mains wire someone has tried to channel into cabin to feed to boot to supply power to an amplifier, or another wire ….
if there are some suspect gaps which you think you need to fill some silicon could be a good idea as a temporary fix
Hope that helps
Rich
Hope that helps
Rich
1.8T CABBY
1.8T CABBY
