Hi, i'm new. Going to own an MK1 soon (hopefully)
(In Topic #72286)
My names Puneet, and am only 19!
It's a 1.1 5door, A-reg.
If anyone has any comments or ideas on what to look out for when i do go to inspect the car, kindly do let me know.
I'm picking the car up for ?100.
Life Member
The big things to look for are rust, rust and more rust! In particular, check the rear wheel arches, under the car near the wheel arches, the fuel filler neck (take off the fuel cap), inside the spare wheel well and the inner wings (inside the engine bay). If these areas are rusty you'll either have a far about of ??? to spend, or will be living on borrowed time.
On the 1100 engine, take off the air filter cover (big black frying pan looking device on top of the engine, about 6 clips around it) and have a look inside, if there is any oil slooshing about in there around the air filter, (or it looks freshly wiped out) the engine is going to be pretty tired out. though replacement engines are pretty easy to source and fit. Look in the oil cap for signs of 'mayonnaise' this is oil+water mixed and means the head gasket is possibly gone.
1100 may have a manual or automatic choke, I prefer the manual as it gives easier starting.
Other than that, general condition is much more important than mileage and obviously the normal car checks (straight running, brakes, V5 etc).
Also have a look at our GTI buyers guide for more clues, most of it applies to the smaller engined Golfs!
Best of luck!
Cheers,
Drew.
Once a Mk1 fan, always a Mk1 Fan...
Heres the car i'm purchasing, this is the actual car itself:-
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4502492117
Kindly do let me know what you think. Photos are a bit vague, but the overall condition from the shell looks reasonable! I bet the creepy crawlies will really be hiding beneath the shell.
All ideas and comments are welcome on the car. I've asked the seller a few questions, he should be getting back to me later on today.
Problem is, that the seller really doesn't like responding/replying to his emails, else-wise, i might have a bargain at hand.
Also, could you kindly let me know if the car in the photos appears to be a Formula or a normal C? Whats the diff. between them?
Life Member
As for the 'Formel E' it was basically a 'lean burn' varient of the 1100 engine, with a very long 4th gear, designed for economy. Best avoided to be honest as the long gear robs the car of what little performance it has, and the lean burn engine is not as easy to keep running as the standard 1100.
Cheers,
Drew.
one quick question. You mentioned that i'd be looking at a new rear hatch because of that little bit of rust?
Is that true? I mean, i'm sure theirs ways of treating rust and using polly fill. And then sanding it down?
Or is that not a good idea?
I'm thinking of ditching it if i'll have to change the hatch (new hatch), simply because of one little rust spot/bubble.
Life Member
If you're lucky you might just have a few scabs around the pin holes for the badges. If you're not then the rear hatch might be full of iron oxide crumbs… :?
Cheers,
Drew.
Life Member
The Formel E had
- high compression 1.1 GG engine
- 3 + E gearbox (tall 4th)
- fuel economy gauge with change up indicator
- windscreen pillar black plastic mouldings
- 2 piece deep spoiler (same as GTi)
- Formel E badge on the back
Otherwise it was the same as the Golf C.
Can't tell how good the car is from those pics, though it looks strange as the sides of the car are grey at the bottom?
Rajan
Yeh, you've got me thinking now. I only really just noticed the grey bits across the bottom of the door. I reckon it's plastic covering of some sort to cover up the body to prevent rust building up. He does say he lives in near the beach, so maybe it had it specially done to preserve the body?
Thanks Early 1800. It sounds really good. I'm really after economy rather than anything else at this moment in time. Would you/anyone happen to have economical figures/quotes of the car to hand?
I.E. Urban MPG, Motorway MPG & Combined MPG?
Looks like i've really found a pot of gold. I won't know till i go and see it, but this car suits every single one of my needs. Especially with it being a formel E.
Not quite sure though yet, rajan has said "- Formel E badge on the back ", the photos don't appear to have the badge.
Anyway, the person isn't replying to my emails or phone calls, so i'm starting to get a bit worried.
If anyone would happen to know of a formel e 1.1 5 door going for about the same price, please do let me know.
P.S. - The Formel E isn't an Auto is it? I really don't understand 3+E, sounds like an Auto to me! I'm guessing it only has 3 Gears, plus the economical which is something like auto :?: *Confused*
Life Member
Edit: 3+E was VW's terminology for the 4-speed manual but 4th gear was longer than the other gearboxes. "E" stood for economy. 3+E was fitted to the Formel E and diesels. Incidentally the Formel E was available for the Mk2 too!
Rajan
I Prefer the MK1's! MK2's look like frogs, or something rather over-grown!
Only prefer MK1's, MK3's and newer!
Bearing in mind i'm a uni student, i think that a formel e would work out better for me.
Btw, i found an article a few mins. back about their also being an upgrade VW released, it was the 4+e, upgrade from the 3+e!
Sounds fun! Wonder where i could source one from? I'd be even more luckier if the MK1 i'm looking at has it all. I really cant wait, but he's not replying to my emails/phone calls. I just called him again, got through to his voicemail (2nd time).
Life Member
Well I've never heard the Mk2 described as a frog before
Good luck with this one, but trust me find a good solid shell and long MOT first.
Rajan
I reckon this one isn't that bad in condition. I'll only be able to report back afta i've had a look at it personally.
Thanks for all your replies.
Just thinking that it'd be great if someone experienced could come along with me to check out the vehicle in question?
Note:- Received a reply from the seller today, the car sounds excellent. I wont really know till i check it out personally though. The car has alot of paper work regarding servicing, if not most, it has ALL paperwork.
Would be great if someone could kindly hop along?
I'm leaving from New street at about 11:30.
Off to Euston i THINK, not sure yet. But the car is in Arsenal.
Can't wait, really excited. I'm going to print off the buying an mk1 section. Many many thanks to this site. It's awesome!
It looks like a bargain to me. I sometimes buy salvage vehicles and a heavily dented Mk 1 GX fetched ?140 !!
You should be OK with this, although rust is the main enemy.
I reckon the alloys will be nearly worth what you are paying for the whole car.
Good luck with it. See you on the main forum.
I'm kind of stuck. Anyone got any idea of how i can get this car from Arsenal to Birmingham?
I'm looking for some temporary insurance to cover me just for a day, as i don't need a proper policy yet.
I'm looking to buy the car, and get it fit and up for it's MOT, and it'll be ready just before i turn 21. I'm 19 now. I'm buying it since my insurance is way too much even on a 1.4!
Would anyone in here happen to be the main policy holder of a fully comprehensive? Because your allowed to drive other cars and your covered 3rd party only.
So, if anyone would be willing to drive it from Arsenal to Birmingham with me?
