heyy! i could do with some help pleease...
(In Topic #125610)
so whats actually wrong with it?
you dont seem to of told us lol
booze and boredom, the greatest mix
u will avto excuse me not been able to explain fully i no nothing about cars! lol, thanks for the replys
also ive been told its got a clutch cable in it for a rover?! i bought the two clutch cables it could be for my car and they were both too long!!
is it carb or injection?
im sure theres loads of people that can help you
im guessing this will be a bit of trial and error
good luck!
It could be the warm up regulator if it's the gti… honestly thogh there are some seriously clever people on here that could help you but you need to put it in the right section. If your car is 1.6 upwards put it in the big block section anything smaller in the small block section.
Web Team
steph1504 said
, and we have had the petrol pipe replaced
Which one and why? Have a look in your fuel tank for debris, common issue, theres an access point under the rear seat to look in there. Sounds like some sort of fuelling issue tbh but would really need to know what engine it is to go further.
Welcome to the site
its a 1.8 carb
the pipes that got taken off were on the carb aparently there wo 4 too many, dnt know if that could be affecting it now,
erm i dont know what pipe, its thin if that helps, lol. they replaced it because it nearly had a hole init and was down to the wire.
thankyou![]()
Pop a post up in the fueling section of the technical boards and we'll do our best!!!
Jon.
