hello again
(In Topic #73831)
hello again
pirelli
it still needs a full respray due to laquer and the sump gasket looking at as theres a bit of a leak
otherwise all looks good to go
1983 1100 C
1983 1100 C
I did the sump gasket on mine in the depths of winter on my back on a gravel drive. WHAT A NIGHTMARE!! In the end I had to admit defeat and get local garage to finish the job off ops: Couldn't get all the bolts in that are tight up against the gearbox housing :evil: GOOD LUCK!
Hairyarse said
..Couldn't get all the bolts in that are tight up against the gearbox housing…
After a load of hassle doing this one myself, I found that two 1/4" drive Halfords socket extensions joined together for length, and using the "wobble-head" feature at the socket itself, allows you to get at these ones, but it's still not particularly easy :roll:
