Which grade oil
(In Topic #218197)
I used 10W40 in my Diesel Rabbit for 20 years.
Just stay away from Storebranded or Fram/Bosch filters.
Stay with WIX, Mann,Mahl, genuine VW.
Stuff VW would put in your car…
AVS Car Parts
Stuff I use but I don't pay that much for it… when on offer or use discount code it's about £12.
https://www.eurocarparts.com/ecp/p/car-parts/engine-parts/engine-parts1/engine-oils/?521776011&1&cc5_245
Stay away from Castrol oil as it's not as good as it used to be….
Briano1234 said
I use 20W50 on my cabbies, and never had an issue.
What's the issue with Bosch filters? I always thought they were good quality.
Current rides:
Specifically they don't have the anti-drain back valve on the filters. While that is usually for side mounted filters and not specifically for the way dubs hang, the other itty bit that the valve dies is to assist in stabilizing the oil pressure at idle.
I have had in the past using Fram or Bosch a intermittent flashy light at idle even tho I had over 1 bar on the gauge.
Switched to Wix, the problem went away magically.
Ironically most of the cars that I see in the wrecking yard have Fram or Jean Erics filters on them co-inky-dink?
Matter of fact the Cabriolet that I got a Pristine Dash Bezel off of yesterday, had a Fram Filter.
https://www.vwspares.co.uk/product_info.php?products_id=1179
Mann filter £5.59 and 33% off with discount.
https://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1989/p/car-parts/regular-service/car-service-parts/oil-filter/?501770059&1&df2e88f773d5c865f404b9dd795cf6fb0b433883&000231
Don't forget a new sump plug washer, 49p
https://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1989/p/car-accessories/car-components-accessories/nuts-bolts-clips-and-ties/washers/?333771221&0&cc5_935
Current rides:
Surely we shouldn't avoid Bosch fuel and air filters or any of their other products?
Guinness_Ben said
Interesting, never knew that.
No, I still use Fram Air filters and or Bosch, or even Store Branded, as they don't seem to be an issue, Oil filters are another matter.
