wheel guru needed...
(In Topic #218293)
Log into Facebook
the seller says they are from an mx5 - the pcd seems correct 4x100, but i just dont know enough to know iff they will bolt straight on!
Roach said
Pretty sure the center bore of MX5 is too small for us VW folk.
ahhh ok - cheers
chrisL said
Ask him for the RS code (001, 301 etc) and that will tell you the bore etc.
Any wider than 7" or lower than an offset of 20 and you're going to struggle, Golfs also run smaller tyres and all of this depends on your suspension set up as well
Centre bore isnt an issue, most machine shops can mill them out
Current rides:
Roach is right, Mazda's bore is a typically smaller than the classier 57.1mm our cars have.
As chrisL stated, ask the seller for the model ID. The price seems fair (IMO) and definitely worth inquiring about.
