Map for early ceramic fuse box (1982 VW Rabbit MK1)
(In Topic #219809)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/eagle.png)
![tonyperry12345 in the usergroup ‘Regular’ tonyperry12345 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I am writing on behalf of my brother, who is restoring a 1982 VW Rabbit Mk1. He is trying to find the map for the fuse box, which uses ceramic fuses.
I believe the code for the fuse box is: FD-HH
Does anyone have a map showing which fuses go for what? (He looked in the owner's manual but this isn't included).
Thanks in advance for any guidance you might have!
Tony
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/WhatsApp%20Image%202019-08-22%20at%2008.jpeg)
![h3lter in the usergroup ‘Paid Member’ h3lter in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![h3lter in the usergroup ‘Local’ h3lter in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
H3LTER said
Thank you!!
I looked through the fuseboxes put together by rubjonny but I can't find mine unfortunately.
896151 SHO
896161
171941821B,C
171941813B,C
811941813A
I've attached photos of the fusebox if that helps. Is this a CE1 fusebox as I thought? Or something else?
Thanks in advance for any thoughts you might have!
![1982 vw rabbit fusebox (front).jpg 1982 vw rabbit fusebox (front).jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1545402222/uploads/attachments/5c1cf76b1637e.jpg)
![1982 vw rabbit fusebox numbers.jpg 1982 vw rabbit fusebox numbers.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1545402224/uploads/attachments/5c1cf76fb03e8.jpg)
