Underseal!!!
(In Topic #233133)
Not mk1 golf related but is mk2 golf related so technically same issue/problem. Really struggling to get the underseal off from car chasis/floor etc.
Anyone resto guys/girls got any top tips on how to do this without
A, paying someone else to do it and
B, setting car on fire!!
Steve
Apologies i should have been more clear. I need to remove underseal to see the extent of any repair work (welding etc)that i need to carry out.
Currently doing a restoration on a mk2 golf gti.
And yes the underseal is very good in some cases almost an inch thick!
Place the dry-ice on the material leave it for a few minutes, then smack the super cold stuff with a dead blow hammer and it breaks right off.
[FAQ] Detailed How To: Remove Sound Deadening Tar From An EH Hatch! - Honda-Tech - Honda Forum Discussion
Underseal!!!
And, remember that when you do remove the factory stuff, you also remove the catholic primer and phosphated layers.
You could go for a full dipping in acid and re- coat in electrolytically, then epoxy prime and a two pack rubberised spray coat and final ‘black wax’, and that’s the best we can do, which is a massive time and money pit , and still not as good as the factory. That’s as close as we can get.
My advice is a good jsteam clean followed by close inspection, and only remove areas that have failed, then re-instate as good as possible ie epoxy primer and 2 pack stone chip resistance follows by a wax / oil based “Schultz.”
