Speedo arm snapper, speedo stopped working(see photo)...how can it nb fixed?
(In Topic #239500)
Half the speedo arm has snapped off, the stub left is stationery, suggesting speedo no longer working. Speedo was always jumping around but eventually settled at the right speed.
I need to remove plastic front superglue arm back on and refit speedo cable. I live surrey hampshire border and need an enthusiast to help me fix it before the MOT
Not really. it is rather brittle plastic, but you can surely try. When you pry it off the center needle do it from 2 sides of the needle. I broke one once… so I use a pair of curved hemostats that opened neatly straddle the center pin. And use a piece of paper on the face plate under the pry's so you don't scratch the face plate.
Probably easier to source a new cluster than a needle.
