Rear Seatbelts
(In Topic #211215)
My little mk1 goes on the road in a week all being well. One thing I would like to get sorted is the rear seatbelts,.
Do mk1 golf tin tops have three point belts in the rear or just lap belts?
I ask as I currently have no belts at all and don't know what I should have.
I would like 3 point belts but these would need retro fitting? I can see Crazy Quiffs sell a kit for a cabby but not sue of its fit in a tin top.
Any advise would be gold dust.
Best wishes, Paul.
Let me know if you need any other info!
Matt.
I will have a good look for the blanking plugs when I am at the garage tomorrow and hopefully pick up some seat belts on here.
I will also check rust, thank you for the heads up, not really what you want to find!
Really appreciate your detailed answer.
Best wishes, Paul
Depends on the year of your car to what fixing will be there at manufacture.
Rear Seatbelts
Thanks Saulty, I will have a look at your posts. Thank you for putting them on here. I think I know the spot you are referring to, it's had some repair work done there before.
If you remove the base of the back seat you should see the holes in the corner and 1 or 2 holes in the middle for the buckles, you will have to feel about in the C pillar to find the hole if you still have the headlining in place.
You may need to change/modify the rear parcel shelf side holders to get the seat belt through if there is no slot in there already? Fixing for the real should be just below the shelf.
You can buy new seat belts which will fit for not much money so don't go paying silly prices for some old vw ones. I fitted new belts as I felt safer doing that.
I bought some for my Mk1 Scirocco so sorry can't help with which model fits a Mk1 Golf.
Seat belts and harnesses manufactured by securon
Just looked at website and I think it's the 264 you need?
1st link I found so shop around?
http://www.ebay.co.uk/itm/NEW-Securon-Seat-Belt-264-Lap-amp-Diagonal-Belt-x1-/250396274489
Will check size and order!
Thank you guys for your input!
I will say that I did add them to my 58 bug-eye, and 67 midget… and I can remember over here that my dad added them to just about every car he ever owned up to 69….. He would buy them the same color as the seats.
Scary stuff!
Got some ordered up and on there way! I look forward to fitting them!
I can remember my dad buying one of these for a Cross Country trip for my little brother…. now who in the world would place that in a car and expect safety…
It's easy to judge yesterday in today's eyes but back then that car seat was probably the front edge of car safety!
Thank you so much for the photos, they are a real help but unfoutunately my car has had an arch repair and there is no bracket for the reel and no holes in the c pillar at all! Looks like it will be some serious work to get the belts in! I don't have a roof lining like yours that is coming down the pillar.
But the car is out the garage and I am driving it and loving every minute. She is running rough and needs some tlc… but on top of that the bonnet popped up on me and bent itself over the roof so its as usual one step forward two steps back.
Will add photos of it if I can work out how to do it.
I have seen threads where they took the brackets and bits off of a 91.5ish Cabriolet and weld them to a earlier Cabby and a Golf (rabbit) over here.
