Front Indicators not working
(In Topic #241963)
Front indicators
mk1 silver campaign totally standard lowered on coilovers magic tree vanilla
Just had a full outer body restore
I would suspect the grounds as if you run a test ground do they then light?
Does each power wire have 12V to frame ground not the case or ground wire at the connector specifically to the frame? if you say yes then you snagged a ground.
If you said yes then you can just run a new ground from frame to each housing.
What year of Golf, if you had the engine out you may have pulled the ground lead but with out the year I can't look at the schematics.
