Front anti roll bar bushes,
(In Topic #212644)
Size
1989 cliper
searching but seem to find different sizes ,
Any advise would be great
Cheers Dan
Instagram Firemandan1
And I would suspect if yours was changed out prior to you owning it for a stiffer rod, then you would need to know the diameter but the inners are different from the outer bushings.
171411313 inner
171411314A outer
There are two listed for stock
inner
https://www.ebay.co.uk/sch/sis.html?_itemId=181442839836&_nkw=VW+SCIROCCO+FRONT+ANTI+ROLL+SWAY+TORSION+BAR+BUSH+SET+171411313+FEBI+02765&_trksid=p2047675.m4099.l9146
outer
http://www.ebay.com/itm/Porsche-924-S-Turbo-944-Sway-Bar-Bushing-Front-Outer-171411314A-Aftermarket-/350792589731
I would imagine vwheritage has them.
https://www.vwheritage.com/golf-cabriolet/mk1-golf-cabrio-suspension/suspension-bushes
Briano1234 said
Are you talking about the front lower sway bar between the control arms?
171411313 inner
171411314A outer
inner
outer
Yes , sorry thats what i mean, Pretty sure its all original down there,,
Is paying the extra for poly bushes worth it, ??
Do you have dental insurance?…It may tend to rattle your teeth a bit.
I don't like Poly….Poly is stiffer, and when it decides to go it turns to powder…..
