Engine oil
(In Topic #244477)
White lhd 83 MK1 golf gti (long project)
Blue rhd 83 mk1 golf gti (weekend toy)
Skoda roomster (Daily)
I even used it in my V8's and V6's with no ill will.
I would recommend no Generic or Store branded filters, and the only one I trusted on my Cabriolets were:
STP
Mobile1
Mahn
Mahl
Genuine VW
Wix.
No Fram, or Bosch, as they caused blinky oil lights at idle.
For the old 500.00 standard, 5W-30, 5W-40, 10W-30 and 10W-40 were all listed as suitable for the full ambient temperature range of between -30 deg C and +35 deg C. Oils meeting the lower 501.01 standard typically covered a slightly narrower ambient temperature range, depending on viscosity.
In conclusion, any oil meeting VW's current 502.00 standard for petrol engines should be suitable, regardless of viscosity range. The equivalent standard for diesel engines is 505.00. Many mid-market and premium oils meet the standard - often abbreviated to VW 502/505 or similar - check the back of the container or the data sheet online. Also check the manufacturing date on the container, as shelf life is usually only 3 or 4 years.
Edit: Just noticed you mention the 9A engine, not an original fitment on the Mk1 Golf, but from the same era, so 502.00 would still be the oil spec to look for. It's only when you get to later technologies, such long life servicing, PD diesels and some recent TSI engines, that more specific later spec oils are needed.
Last edit: by typ_53b
