Wiring on ABF conversion
(In Topic #140880)
Also does anyone know how to cure the constant flashing water temp light when doing the ABF conversion?
Last question…what colour are the wires which go to the air flow meter on the ABF engine?
Thanks all!
flashing light could be water level sensor, what looms are you using for this? the level sensor is on the lighting loom on a mk2 gti, red/blue wire and brown/red.
abf doesnt have an air flow meter, unless you meant the inlet temp sensor? if so its yellow/white and brown/blue
Using mk3 loom which has been spliced into mk1 keeping the lighting Plugs and swapping over plugs for water, exp tank etc. Engine part nearly done, moving onto dash loom next hence few questions.
Yes it's the inlet air temp and that's spot on, thank you
ah, you're using mk1 clocks and mk3 level sender wiring? the light shouldnt flash if the control relay isnt fitted with the mk1 dash it should ignore the level sensor wiring completly
Can anyone help here, this is the wiring of the loom for the lambda/oxygen sensor and the plug is the sensor, which wires go to which, appreciate any input, many thanks
but the wire colours are as follows:
1 - red/wht (lambda heater power)
2 - brn/blk (lambda heater earth)
3 - yel - (lambda sensor earth)
4 - wht - (lambda sensor signal)
My theory is that its for speed limiter and/or for the ecu mpg signal calculation
Just the indicator telltale on dash, I have a grn/blk and wht blk off the ce2 loom and a single blue/red from the ce1 dash loom? Now I've looked at RJ's wiring diagrams for 1989 Jetta nd 1991 golf and I can see a grn/wht/blk wire which I cannot physically find on the car? Am I barking up the wrong tree with this?
These I seem to have left over or the label has fallen off:
A single red marked as digi clock?
A thicker wht/yel?
A wht/blue?
Lastly a blk/yel?
CE2 black/white/green wire goes from H2/8 to the hazard switch pin 49a, the CE1 equivalent wire is black/white/green from A/18 to pin 49a on the hazard switch and indicator stalk. take a close look at your wires, its not liek a triple stripe its 2 colours and like dots if that makes sense
with those wires where do they come from? red could be perm live for dash, wht/yel could be front fogs, wht/blu could be speedo signal and blk/yel could be anythign loads of them
The random wires are all with the oil pressure signals, headlight flash etc and the other stuff for the clocks, I'm splicing them into the white cabled loom which would have gone to the mk3 clocks so if I've got my head the right way around, those wires are coming from the CE1 clocks and are going to the CE2 fusebox, U1 and U2, I think!
T14
1 - blu/gry - Lights on feed
2 - brn - Earth
3 - pur/blk - Fusebox pin B/3 (fuel level sender)
4 - blu/yel - Fusebox pin B/7 (coolant temp sensor)
5 - red/blk - Fusebox pin B/19 (rev counter)
6 - red - Fusebox pin B/12 (permanent live)
7 - blu/wht - Fusebox pin A/28 (high beam warning)
8 - brn/wht - MFA switch mode button
9 - yel - Fusebox pin A/4 (high oil pressure warning switch) (blk/blu on early models)
10- brn/red
11- blu/blk - low oil pressure warning warning switch (yel on early models)
12- blu - Fusebox pin A/16 (alternator warning light)
13- blu/red - Fusebox pin A/17 (indicator warning lamp)
14- blk - Fusebox pin A/8 (ignition live feed)
T6
1 - wht/blu - outside air temp sensor
2 - wht/red - outside air temp sensor
3 - grn/blk - Fusebox pin B/15 (oil temp sensor)
4 - blk/yel - Fusebox pin A/3 (Gearshift control relay pin 3/L)
5 - wht/grn - Fusebox pin B/18 (Gearshift control relay pin 5/G)
for CE2 cluster, see here:
http://www.clubgti.co.uk/forum/showthread.php?t=219775
I think I'm starting to get the hang of this malarky finaly.
Off back down to connect up headlight warning and perm live now.
The gearshift control relay at T6, I'm presuming I dont need that?
You deserve a medal!
Sparks
Ht Leads
Dizi cap and rotor arm
Battery
The new battery turns it over strongly, the fuel pump is buzzing away, ISZ is buzzing on ignition, 1/4 tank of petrol? Ive taken the injector rail off and watched all 4 produce mists of petrol to each chamber.
The coil and lambda are both second hand mk3 items, should I start here. I've still got the original coil, tci and wiring? Am really gutted because its just about ready for MOT but I cant get it there now. Pants!
ecu temp sensor and crank sensor would be on my list too
I'd also tried what you advised and had tried another mk3 coil and a mk2 one but no joy. Thank you once again RJ.
