wilwood brakes
(In Topic #139775)
wilwood brakes
i recently got a pair of wilwood 4 pot brake calipers and not sure what hoses to use. the hoses screw into the back of the calipers and not the top so is there some hoses with 90 degree bends on the ends. i didnt get a kit just the calipers and brackets
also there does not seem to be much room between the pads i measured roughly 23 mm and the person i got them from said to use g60 discs which are 22mm new. does anyone know if this is enough for them to move properly also they will need to fit over the discs perfectly
i am going to have to wait until i get the mounting brackets to put them on but i will need to sort hoses out for when i get them.
You will need to make some custom ones, look on rally design and build some from euroquip bits.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
Re: wilwood brakes
just scuff the pads down a but lol
thanks but there is still only 23 mm gap in the caliper i might contact a supplier of the mk1 kits as they must sell the 20mm discs seperately.
