Which Gearbox
(In Topic #146375)
Which Gearbox
I am after a bit of assistance as to which gearbox would be suitable for my engine conversion;
The engine I am putting in is a 16V KR with
2.0l TSR short engine fitted with a and AMD stage 2 ported an polished head with a custom ground inlet cam and standard exhaust cam and jenvey throttle bodies and an emerald ECU. My concrn is that even with a relatively mild map it will be up around 160bhp and with 2.0 ltre block and the inlet cam is designed to improved low rev range torque it may be a bit much for the 020 gearbox.
Any suggestions? I did think about a TDI gearbox but thought that would probabaly be a bit to long on the gear ratio.
Anybody ??
Lee
if you do for for an 02a box the abf gearbox is a good match for that i think, or g60. tdi may be a bit tall for an n/a valver, they're more in favour with the boooost boys
Which gearbox?
I appreciate the latter gearboxes (02a etc) have a larger diameter clutch but given your power and torque the 020 should cope without any problem.
ME 926
ME926
Been of the grid for a while due to illness, all fixed now and about to start on my wifes toy again. Decided to go a different route with the engine so I have a 165bhp KR engine with an AMD Technic head complete with custom ground inlet cam (K-plus upgrade it was called). The dyno print out I have that goes with it shows 165 bhp with a 15% increase in torque which comes in at about 1500 rpm lowere than the original cam, stainless supersprint manifold and down pipe, loom clocks ecu and all the bit for the conversion and the drive shaft hubs, MK 2 16v fron tand rear callipers etc.
If anyone is looking for BBR rs and struggling to find the correct offset in a four stud as I was I have just had some re-worked from 5 to 4 by TTL tooling down in Essex and you struggle to see where the old 5 studs were originally outstanding worksmanship. Cost £300 for the 4 but well worth it. I will post some photoes when I get back to the UK at the end of the month.
Been catching up on some of the build threads like Mike_Turbo ( that is an impressive piece of engineering) and will be posting my progress as and when I make any.
