which car do i need please
(In Topic #143737)
Engine fitted and apart from the engine do i need anything but the engine . :dontknow: Any help here would be great as this is new ground for me . As mk1 and mk2 S are were im happy .
Id also look into 9a (2.0 16v) or even 6a (2.0 16v) engines
What model mk1 are you converting (engine size)?
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=99922
What you need depends on what set up you want to run, im putting a 2.0 16v in my mk1 but im using the original kjet system for fuelling and the original 8v gearbox so all I needed was the engine, the engine ecu / ignition module and wiring loom,mk2 golf 16v throttle cable ,16v conversion exhaust manifold and to fit the 8v clutch flywheel to the 16v engine so that the gearbox goes on.
I would put a 2.0l ABF engine in the mk2 golf shell mybe :angel:
the SEAT ADL 1.8 looks similar to an abf as the engine managment is nearly the same, but underneath its still just a kr lump
