Wheel Spacers
(In Topic #75805)
Wheel Spacers
Hiya gang,
Ive noticed that my rear wheels arn`t quite in line/parallel with the front ones on my campaign. So i was hoping to push them out to give it the "phat" look to fill out my arches
So i was wondering which size of wheel spacer would be best to get `em to line up—– 5mm or 10mm? Also will i need longer threads to put `em on? And is it an easy job?
Has anyone elso fitted spacers? :dontknow:
Lookin forward to hearing all your opinions….
Stay out of the black…
And into the red….
You get nothing in this game for 2 in a bed!
And into the red….
Don't space the wheels, chances are you'll loose the use of the centre spigot and potentially damage your wheel bolts.
If you want to increase the rear track then space the stub axles from the beam and get longer bolts to suit.
Oh i didn`t know that Stew72! 8O 8O
Didn`t know it prove to be dangerous to space `em out. Where would i get hold of stub axle spacers from; and how much would they set me back?? :dontknow:
taa….
taa….
And into the red….
And into the red….
Not sure.
Best bet is to get a local machine shop make some out of certal (sp?) plate the correct thickness. This shouldn't need machining to thickness as the material is already machined to a nominal thickness.
Hope this helps.
Hope this helps.
