What feul pump to use for MK1 VR6 conversion?
(In Topic #138491)
Anyone know what feul pump to use for this conversion or any pointers/help on this will be appreciated.
Pics if the install would be even better!
Thanks!!
rubjonny said
no need for a pressure reg, the vr6 has one on the fuel rail. but yeah mk1 gti pump is what you want
Thanks mate,what lines would I use,anything specific?
rubjonny said
try the mk3 lines, might work ok! if not decent rubber lines rated for fuel injection should do, try to get braided as they have a bit of extra protection from stones or whatever
Thanks! Any tips/instructions on how to install the feul pump,i know it simple but havnt done it before?….
rubjonny said
nee bother lad!
Hi mate! Me again!
rubjonny said
what fusebox is it, early ceramic or later blade?
Blade….
then you will need to run the fuel pump power pin either to E/14, or the large spade N. e/14 is fused, you need the large size round pin to fit into it, you can buy them or just raid a spare wiring loom. spade N isnt fused so make sure you fit an inline fuse is you use that.
then you use a fuel pump relay 67, 80 or 167
rubjonny said
right. if you want to make use of the factory fuel pump relay socket, first you need to run the ecu fuel pump trigger wire to D/13, this will allow the ecu to control the fuel pump relay (goes to G1/3 on CE2 fusebox)
Mmm…ill give it a go! Lol!
So just to confirm…one line from tank in to feul pump and then to the motor and one return in to the tank,or is there anything else to it?
wiring sounds complicated i know sorry
D/13 you need a small round pin again nick it from a spare loom or crimp on a fresh one. the pin numbers are stamped into the front of the plugs too to make it easier to find them
rubjonny said
forgot to ask, what fuel tank do you have?
wiring sounds complicated i know sorryE/14 isnt so bad as its the only large pin in the plug, you cant miss it. plug e is the black one in the middle (see fusebox sticky)
Thanks mate, im sure Ill get there!
Its the standard mk1 gti fuel tank, not changing that. But do I do away with the accumulator? Also the pump has a "screw in" outlet tip so I presume I'm going to have to get the appropriate pipe for this connection and then run it to the front?
you need something like this to convert the pump to push fit fuel hose if you get rid of the acummulator:
http://www.ebay.co.uk/itm/12MM-BANJO-FOR-8MM-HOSE-M12x1-5-BOLT-FUEL-OIL-IN-PLATED-STEEL-/390454742940
or this:
http://www.ebay.co.uk/itm/Bosch-044-Fuel-Pump-Outlet-M12x1-5-to-8mm-5-16-Barb-Aluminium-Adapter-Black-/170694336786
