What Driveshafts Do I Need?
(In Topic #122033)
JassiKundi said
If its any help the gearbox is from a mk1 golf 1.6
ive just done the conversion myself from a 1.1 to 1.8 16v kr. drivers side driveshaft is the right length and will fit if you take the driveflange from your 1.1 gearbox and put that on the 1.6 box. as for the passanger shaft is to long so go for a mk1 gti 1.6 or 1.8 8v shaft and swap your 1.1 inbord joint and drive flange and heypresto your sorted fella if this is confuseing give me a ring on 07769343694 and ill talk you through it mal
I'm sure u'll shift them.
