What clocks ?
(In Topic #100124)
What clocks ?
I have a 92 Rivage cabriolet,
It has had a 2.0 16v engine from a Mk3 golf gti put into it,
It has Mk3 GTI clocks stuffed in dash, that dont seem to fit ?
The speedo is electronic, not cable,
Is there a set of clocks that fit my dash that use an electronic speedo connection ?
Or different brackets to fit the Mk3 clocks ?
It is quite easy to make it cable again , the sender is from the VW parts bin and if you remove the top you will see a speedo drive . Fit a Passat cable and some MK2 clocks ! Have you a picture of the clocks fitted ?
Link here…….. The Mk1 Golf Owners Club
Im sure there Mk3 ones but il check,
So mk 2 clocks would fit, why a passat cable ?
Can i use a golf one ?
My rivage has a computer function on the right hand stalk, are there clocks with the computer built in ?
