Weber Carb Upgrade - Please Help
(In Topic #76891)
Right, from doing some research i think i need a 32/34 DTML Carb.
But, the Webers i have found that say this also state that they are to replace the Pierburg 2E2 carburettor and im sure mine is a Solex unit?
Is this the reason for the Adaptor plate, and will this plate be easy to make/get made for the car?
If someone could clear this up then hopefully i can get my Mk1 up and running well!!!
Golf Mk1 Driver '83 - Gti Replica
Polo Mk5 Gti '00 - Slammed on OZ Turbos
2modified.com - MK1GOC Discount Available!
Doh!
Forgot to mention my car is a 1.3 Driver
and i posted it in the wrong section, can a mod please move ?
someone please?
Need advice before the weekend :mrgreen:
Thought Pierburgs were only fitted to the mk2? Haynes just states a 34 PIC-6 as the carb type for 1983 1.3. Where are you buying the carb from?
1983 1100 C
1983 1100 C
Ebay, i have read it on here that is the one to get im sure!
Can anyone tell me different, really need to know asap
Any Contributions greatly aprreciated, thanks Mark
Is this the one? From what it says it is from a 1.6 mk2 golf (although could be a cabby?) and the adaptor plate will be to adapt the carb for a mk2 manifold. The question then is, is their a difference between a 1.6 mk2 & 1.3 mk1 manifold? Which sorry to say I don't know the answer to
Steve Matthews (he posts on the forum under that name) knows his stuff when it comes to small blocks, manifolds and carbs, sure he would know. Might be worth sending him a PM.
Good luck
Good luck
1983 1100 C
1983 1100 C
Your best bet is to speak to somewhere like Southern Carburettors (sorry, don't have a number but Google them) and ask them for a plate.
If you got no joy from them, I should be able to knock you one up and post it down to you using gaskets as a pattern.
Best of luck,
Steve
Best of luck,
Steve
So that is the right carb Steve that i should be buying?
As for an adaptor plate, that would be brilliant, how much ? we talking?
John
John
That carb would do the trick nicely.
Adaptor plate - not much money at all
Cheers Steve, will get the carb bought then, anything i should look for when buying?
