vdo
(In Topic #85377)
vdo
hi,
ive got some audi vdo guages which fit a mk1 gti, installed but not wired. all that comes from the other side of the vdo is wires attached to the back. what else do i need to get them working, such as wiring looms etc?
thanks,
simone
thanks,
simone
Which guages have you got? Assuming temp, oil pressure and volts. For the temp you need to wire it to the temp sender and earth, for the volts you just need an ignition live feed and earth and for the oil pressure you need an oil pressure sender 5bar or 10bar depending on which guage you have. I have one on back order from bigboystoys (for the last 4 months) - still not turned up.
