uprated steering rack bushes
(In Topic #86963)
where can i buy these except from powerflex
bugpack do them but i cannot find any dealers that can supply ??
A complete set costs les than ?60.00, search ………
Cheers………
i only need the rack mounts tho as everything else is done
What are the quality of the bugback bits like? Ive seen them on ebay but always thought they are remarkably cheap for poly bushes.
mk1 1.1 C
Guest user
They are based on the original VW items (even have the part numbers!
They have been perfect for me, obviously makes the steering tighter but get more vibration through the wheel, especially if you have bad tracking/incorrect tyre pressures etc. Also make sure you use all the of grease it comes with, I was stuiped and used it sparingly, now when I use full lock I get a squeek as I turn! :roll:
AndyCEB said
They are based on the original VW items (even have the part numbers!)
Also make sure you use all the of grease it comes with, I was stuiped and used it sparingly, now when I use full lock I get a squeek as I turn! :roll:![]()
Give the bush a squirt of WD40 or 3in1 oil and your squeek will go !
You can buy all these bushes seperatly from 'Rally Design' 'Demon Tweeks' or Bigboystoys Vw
Google for web sites……….
