Twin 40s Running with a Turbo
(In Topic #93517)
heres the deal i have brought a turbo kit and a set of twin 40 DHLAs and iam going to combine them, and iam just wondering if any1 can give me any info on any at all.
iam wondering more about the air feed set ups, for example the air filters, feed from the turbo, that sort of stuff any info would be great
Rob
I personally wouldnt bother using them if you were dead set doing it that way
Jedermanns Wunschtraum…
ein Volkswagen
ein Volkswagen
turbo or supercharged on carbs
i've got an abf engined mk1. want to go carb rute. but also want forced induction. :dontknow:
not that it doesent have enough power already. just being greddy i suppose.
is there any one on here that has had forced induction fitted to an abf?
can you run forced induction on k-tronic mfi?
just after some info/advice really.
cars not a daily.
1457 gx, matalic green. 5 door.
volkswagens dont leak they mark their teritory
MK1US said
I've seen guys run these kinds of set ups on their old BMWs…primaraly with a 32/36 webber. Underlight boost they they seem to hold up. But even the CIS injection system on the MK1 will only take so much boost. I've heard from an old time british racer that carbs will take about 5 psi of boost. Which is nothing to snarf at.
you can run turbos with carbs, that's not in any doubt. cis only takes so much boost? tell that to the ur quattro rally drivers.
Rob
I've had a carb turbo'd car and when pressure tested the carb was terrible for holding pressure, comes out of the throttle mechanism and the choke flaps and all the little holes!
I'd build another though it was great but the jetting is really what you need to worry about as it is a black art unless you know what you are doing.
I have a 16v manifold you can buy if you like to fit weber 40's to a 16v engine, good condition send me a pm.
Paul
ein Volkswagen
ein Volkswagen
tallika_fan said
The lotus esprit turbo used the dhla 40's
just realised that they are 45's not 40's on the esprit.
