turbo conversion from a carb engine help!
(In Topic #140228)
head with cam and pullys gaurd and rocker cover also ecu i think its difag…… So is this all I need for the conversion or this not going to happen. I'm only thinking of going down this road for bigger specs an because I can get all that at a good price….
Cheers for help
mk1 golf 1.8 8v = sold
mk2 golf gti = burned out
mk3 VR6 = wrote off
mk2 seat ibiza gti = sold
mk5 jetta tfsi = stanced and slammed
Mk1 golf = garages and butt naked
mk3 VR6 = wrote off
Regards Volkswarren
Use the G60 ecu and plenum arrangements and forget the carb setup, itll be a pita.
Be aware that if the CR is too high to start with itll limit how much boost you can run before it starts detonating.
good intercooling and heat management can help there.
found a compression plate that would go in between two head gaskets on eBay for about 60 quid, all I needed to do was hack the turbo into the exhaust(made the templates) and then the turbo inlet into the intercooler then into the carb. While I was talking this through with the fellas here I also found it would only raise the boost to around 9psi or something.
So really it was a loosing battle, but would have been a lovely talking point hehh.
Also the oil supply, I was going to use a MOCAL electric pump, catch tank & oil cooler(demon tweeks)
Got a nice Garrett turbo with no play in it at all and an intercooler here if you wanna buy it.
EDIT: heres the topic: http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=109580
I'm so flipping lonely, it's killing me lol at least I can laugh about it!!
