tt project
(In Topic #84956)
tt project
I want to put a TT 1.8t in my 83 golf GTI, i wondered what parts i would need like:
Hubs
Driveshafts
Gearbox
any others
if anybody has done this conversion, it would be a great help to me if you could tell me how hard you found it.
Thanx
Front original engine mount
Mk4 drivers side mount with home made adapter plate
Home made passenger mount and rear mount
Audi A3 02J gearbox and selector
Scirrocco mk2 driveshafts (bigger diameter and ends fit on gearbox)
Hydraulic clutch for 02j box fabbed to fit mk1 pedal and pipework modded for master cylinder
16v servo and master cylinder
Audi 80 brake fluid reservoir
16v radiator with thin kenlowe fan
custom rad pipework
Pace front mount intercooler
Homemade I/C pipework and exhaust manifold and downpipe.
If I can think of anything else I will let you know or if you need any information please feel free to ask me Im no expert but I might be able to save you some time and money.
Also i dont know what brakes and suspension to use.
depending which engine management you use will depend weather the original dash can work I use DTA and you can wire the rev counter up and if you swop the electronic pick up in the gearbox for a gear type Eg mk2 golf one then the speedo will work.
Ive fitted 280 mm brakes up front with 16v servo and master cylinder and goodridge braided hoses throughout.
On the back ive fitted mk2 rear discs.
The suspension is Weitec uprated and lowered suspension
also, when u mounted the engine, did u have to weld or anything? Did u find i hard to do?
another thing, what was the total cost when u finished?
I wouldnt attempt this conversion on my own and Ive got some good mates who have helped me with it.
I helped a mate when we did his mk1 quattro conversion but mostly its just a case of taking your time and I dd mine as I went along but its not really the best way if your on a budget as I must have spent nearly 15 grand on it
If you need any help let me know I dont profess to be an expert but I might be able to save you a bit of time and money
