Top Fill Radiator
(In Topic #118219)
Top Fill Radiator
I think i owuld like to go for a top fill radiator would this in turn do away with my expansion bottle ???
What are the Pros and Cons of them ??
Are they very expensive ??
Are they easy to fit and maintain ??
Only has an inlet and outlet pipe?
Sorry I can't be of more help :dontknow:
you need a big block top fill radiator - i.e. 1.5+ paul_h has just fitted one in his mk1 g60 in the projects section.
fits beautifully with the sprinter intercooler. the top fill radiator lets you do away with the expansion tank, the only downside i found with mine was that you couldn't assess coolant levels with the cap on, like you can with an expansion tank.
i got one for my golf (1.3, so cap at opposite end) from GSF for about 30 quid 2 years ago, i'd imagine you'd be looking at the same price for the big block one - paul could confirm price and where he got his from.
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
G60
Apparently there only held together with tabs just bent over, I queried the sealing and the reply was " Used some high temp sealer, not had a problem yet"
Food for thought.
MK1 83 Jetta… 2ltr 16v ACE
MK1 88 caddy pickup 20VT soon
MK2 Golf 90spec 2ltr ABF coming soon
T5 TDI
T5 TDI
dubassasin said
I read a post recently on the caddy forum where a member took their top fill rad apart and mated the plasic section to a 16v rad core section. Thus creating the 16v top fill rad.
Food for thought.
Have you a link to that thread mate please sounds intresting.
http://www.vwcaddy.com/showthread.php?t=36560&highlight=top+fill+rad
http://www.vwcaddy.com/showthread.php?t=31084&highlight=top+fill+radiator
T5 TDI
T5 TDI
Guest user
Be aware it's much harder to get all the air bled out of a VW system w/o the external expansion tank. A semi-permanent air lock often is present during/after the first fill up, possibly causing localized over-heating and/or poor heater output. You may have to remove one of the heater hoses to get the system properly bled. Even then, keep a watch of the coolant level in the rad end-tank the first few weeks as it may go down some more as other smaller air pockets in the system eventually work themselves out. These are among the reasons VW went to the external, high-mounted tank.
The system is filled though the filler neck on the radiator and should be filled to about ?? to 1? below the bottom of the filler neck. If the system is filled any higher, it will be over full and the excess coolant will be vented from the system. This happens when the heat builds up within the coolant, it expands, increasing the system pressure above the pressure holding capability of the pressure cap (listed on the cap in pounds per square inch or PSI) causing the excess coolant to be vented out through the overflow vent which is exposed when the cap sealing plate is forced upwards. The excess coolant is then vented to either the atmosphere or into an overflow tank, which functions as a catchment basin. The overflow tank is under atmospheric pressure while the cooling system is under atmospheric pressure plus the pressure generated by the heat expansion of the cooling medium
may not be worth considering, but interesting none the less
Good read and i think i will try to fit everything in the bay with the expansion.
83 MK1 GTI G60 85 MK2 GTI 20VT 2004 SEAT ALTEA 2.0 TDI SPORT
It's a valeo one for a golf 1.5. 'tis also running a slim line pusher fan instead of that messy junk VW fitted.
Seems to be running fine, bled it out without the cap on.
You'll need a 16mm bung and a bit of pipe to complete the conversion, as you'll be left with a spur on the metal waterpipe (if your running an 8V )
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
Basically take the thermostat and nut out of the section of the 16v rad (the bit your doing away with)
Drill the 22mm hole in the top fill section and push the nut into the two nibs of plastic that are there from the moulding process. you'll see them.
was going to pressure test but ran out of time…..
T5 TDI
T5 TDI
dubassasin- any news on how it turned out? is it worth doing?
ive been reading up on top fills and ive seen a few people have done this.
just no follow up after they have been made.. so… :dontknow:
its a brand new mk2 rad, home made to be a top fill ;-)
i messed the fins up a bit, but it works
Cheers will
