Throttle position switch wiring 16v KR help!!!!
(In Topic #146435)
Hi I'm just finishing of a caddy 16v conversion (kr) and i've come a bit stuck with the last piece of wiring. the original caddy loom was in a state and the 16v loom was just as bad. The problem i've got is the throttle position switch. 3 wires black/yellow goes to the ECU & the ISV box but not sure about were the other two wires go?
Help needed.
Help needed.
black goes to an ignition live feed, white to the cold throttle enrichment valve (metal thing on airbox) see my sig for complete wiring diagram, 2krecuce1.pdf
Your a star
I'll be getting that wired in tomorrow, Thank you very much.
Allan
Allan
