TDI engine conversion
(In Topic #79738)
I'm looking for a new project for the summer and i'm quite liking diesels at the moment. Love the monster torque.
Anyway, i was thinking of putting a TDI engine into a Mk1 so i've got a couple of questions!
Will an AHU engine from a mk3 fit on the mk1 GTI mounts? And will i need to fabricate a pair of drivshafts or are they the same lenght?
Thanks in advance.
Regards Volkswarren
I've got the doner car, Golf 3 TDI P reg. So ive got the engine, box, ecu, ignition barrel, loom etc. I'll need to get some clocks but i figure i can get them from a diesel caddy. Not sure how easily they'll wire up though.
The main obstacles i can see will be the driveshafts and as you say the exhaust downpipe.
Will the TDI driveshafts fit the Mk1 when used with the 02A box? And will it mount up ok with this box?
I would think so [ i have been looking in to a 020 TDi box for my 1800 petrol ,relaxed cruising speeds etc ] Still looking ! Thinking of building one from bits!
But of course with your diesel conversion you will have to be carefull with the gear ratios or you wiil be reving the nuts of it at top speed and lose any gains the Tdi would give you .
www.vwcaddy.com
dub-ha8 Thanks for the info. I'll get in touch with him and see if he can give me any advice.
From what i gathered so far it's gonna be easier to use an 020 box as i think i will have to fabricate a mount to use the 02A. I'll just have to play around with the ratios.
Caddy clocks will be of no use to you.
