Stuck adjustable suspension
(In Topic #149918)
Hi All,
My adjustable suspension is stuck solid, does anyone have any good techniques/words of wisdom for getting it loose??
Really want to make the ride more comfortable …………….. Yes I'm getting old!! :p
thanks
Drew
thanks
Drew
/Users/cherie/Pictures/iPhoto Library/Originals/2008/16 Sep 2008/DSC01016.JPG
Assuming coilovers rather than normal type shocks with adjustable spring platforms then give the threads a good clean with the wire brush and a liberal spray of plus gas (make sure to cover your brakes with plastic so you dont contaminate them) leave them to soak while you have a brew then spray them again above and below the nuts and get a pair of c spanners on there (one alone wont work properly), i would avoid using heat at all and if you still cant get them off its time to see if you can buy new nuts from the supplier
Yeah they are coilovers! Thanks I'll give that a go
