Some 20VT Questions. Clutch etc
(In Topic #150017)
Hi there everyone. I am currently doing a 20vt AGU conversion into my LHD MK1 Golf
I am going to use the old 020 gearbox for now but have been warned that I need an uprated clutch. So would this be an uprated clutch made for a mk1 gti as standard?
Anyone know where i can get a reasonable one for a fair price? I have a new clutch kicking about for the 8v engine. I imagine they are not strong enough?
I also will be looking at having my ecu remapped. Could anyone recommend a company that has a good map for this conversion please?
I am also pretty keen to know which pipes i need to get for my front mount intercooler
Sorry, also anyone know which throttle cable would work for me? Its Left hand drive!!??
Thanks. Any help would be greatly appreciated
that 020 won't last very long, for what it will cost, get an 02A box in there first.
Can anyone recommend which 02a code is best?
i asked a question about up-rated clutches a few month's back….
was told by another forum member who is a guru on this site, that a standard oem clutch for mk1 gti with 020 box is rated to take up to 210bhp if i remember correctly…
this would be a sachs clutch..
i have fitted a black diamond stage 1 and im having trouble with the clutch being very stiff/heavy.. have broke a clutch cable already…
hope this help's
adrian
hope this help's
adrian
O2a ratios here. Work out from there mate.
ATA,AGC 3.778 2.105 1.345 0.971 0.795 3.684 Corrado G60, Passat 16v
AYL,AYK 3.778 2.118 1.429 1.029 0.837 3.684 Corrado G60, Passat 16v
CDM 3.300 1.944 1.308 1.034 0.838 3.647 Corrado VR-6 2.8
CDA 3.300 1.945 1.308 1.029 0.837 3.68 Golf III 2.0 16V, Ibiza 2.0 16V
CBA Corrado G60
3.778 2.118 1.360 0.967
0.769 3.647
CHA 3.778 2.118 1.360 0.917 0.717 3.944 VR6 Canada
CNL 3.778 2.118 1.458 1.029 0.837 3.684 VR6
CCM 3.300 1.944 1.308 1.034 0.838 3.389 VR6
CES 3.778 2.118 1.429 1.029 0.837 3.684 Passat
CGY 3.778 2.118 1.458 1.029 0.837 3.684 Passat
CAW 3.778 2.118 1.458 1.034 0.838 3.647 Corrado
I've got a g60 cba, ayk is very similar to the g60 box.
vr6 box doesn't fit the 20v block from memory
hope this help's
adrian
thanks mate. I have gone for the o2o setup with original clutch as you said so hopefully it will all be ok!!
Expecting the gearbox to die quite quickly though!
CBA Corrado G60
0.769 3.647
cheers bud. Im going to run the o2o until i can get the time and money to convert it all!
