single wiper
(In Topic #75660)
single wiper
first golf mk1 im 20yrs old the car is older than me,
golf c 1.1 x plate
golf c 1.1 x plate
Looks naff and doesn't work particularly well, plus means you drilling a new hole in the scuttle and having to fill the old two!
My Build Thread
IN a Nut shell You need to increase the throw of the level connected to the wiper motor by 10mm (use an arc welder). Then chop down the wiper assy so the connection levers clear the wiper bracket. You can than fit a blanking crommet over the disused hole. The only problem is that the wiper motor assy than vibrates alot.
MK2 GTi 16v
wirings tricky tho'
1272 driver with a magic tree!!
AL_Mk1 said
Easy enough to do with the right bits, though I would not recomend it.
al… u cracked me up with this one
i think it really cleans up the front of a car
d
the panel where the wiper comes through before the bonnet and at tht botton of the windscreen has two holes usually
my car only had one! and i mean one smack in the middle and i cant see where the other holes have been welded.
so i went and bought a wiper motor which i thought ide modigy but hte middle arm bit doesnt even match up to the existing hole!" is there an explanation to this??
Birmingham
d
Birmingham
Re: d
c11rgd said
true but how do i solve me [roblem anyone got a diagram of how to mod the orignal?
Mate, if you fail the MoT, you can't drive the car on the road! Doesn't it put you off? Its not like a decat or something, its not easily reversible. You'd have to re-drill the original holes; or modify/replace the linkage another time, just for the MoT.
yea ive been told about these fiat uno ones?
cant seem to find any of em anywhere. neither the scirocco ones aswell.
anyone got one let me know!
Birmingham
d
Birmingham
f
might have to use teh one from a Peugeout 306 rear, ive tried teh rear corsa one, the hole on that is too big!
Birmingham
blue neons, and big-bore cherry bombs to follow…..
Stay out of the black…
And into the red….
You get nothing in this game for 2 in a bed!
And into the red….
f
Birmingham
