Seats
(In Topic #82108)
Seats
I also found that part of the subframe is too low with my soundproofing and carpets in so had to hack it off with a hacksaw accordingly (only on the outside of each seat…)
HTH
<edit>You will also need to either swap the seatbelt stalks on the seats for mk1 ones or put corrado catches on the mk1 belts</edit>
So many dubs so little time, so much rust
benji said
sorry to hijack the thread, wozza if the adjuster handles are on the wrong side, can't you swop the seats over or would the tilt mech be on the wrong side then?
Hijack!!!
Then the seatbelt catch would be on the wrong side, wouldn't it?!?!?!?
Tian 8O
My Build Thread
AL_Mk1 said
You can swap the slide adjuster handles over….
But then the handles for the height adjustment have to come off as they are in the way…
I think I am going to try to get some tube welded in place on the chassis so that the adjuster pin sits in there and works as it should do. No swapping handles etc & mk1 seats will fit back in with no messing too…
my mate has this problem in his golf and it is a pain tryin to get in the back obviously the seats came from a different car but why in gods name put um on the inside i mean , did someone sit there design it and just laugh at the thought ….
maybe im the only one that finds this bizare
Golf MK1 Cab 83'
Ultraviolet purple / Forest green
AKA - Dragon
AKA - Dragon
woZa said
They only end up on the inside if you swap the seats around… Drivers to passengers and vice versa. You only do this because the slide adjuster is on the wrong side… Originally in the corrado the adjuster is on the outside.
Really, that's amazing!
Tian :lmao:
Tian :lmao:
Errrrmmm… :dontknow:
woZa said
Tian :lmao:
Just messin'
Tian :wink:
