seat 2.0 8v engine into a mk1
(In Topic #114978)
does anyone have any experience with this or know whether it would fit easily?
at the moment i have a standard 1.8 gti engine in there.
would there be another engine that I could put into my car that would be a bit easier? or do you think all engines are going to be a bit tricky?
another engine I've been looking at is a g40 but don't know how hard they are to fit…easier or harder than the 2l 8v?!
Luke
It really depends on your skills - if you have all the skills to do an engine conversion then its easy. If you don't, then its not. If you have most of the skills then you can learn the other bits, if you have hardly any skills/experience then any mechanical work will be an uphill struggle.
Once you get the loom stripped down there arnt actually that many wires to worry about, the loom is mostly self-contained within the engine bay as its all connected direct to the ecu, you just need to give it power & earth, plus sort out a way to run the fuel pump. 2 ways to do this, either use the ecu earth trigger and wire this to a digi fuel pump relay, or simply leave the odl k-jet relay in there and let that handle it. Only thing is if it has a rev limiter built in, you'll want to swap it for a relay that doesnt.
fueling wise you'll need to bend the lines over to the driver side, with a bit of careful routing you can get tyhem into the right spot without cutting, push the threaded end down the line then push on the efi lines and secure with 2 fuel line clips. The flared end should stop the lines coming off, plus they arnt under high pressure anyway. Other option is to find threaded fittings with barbed ends (chop 2 old k-jet return lines up and you'll have the fittings you need)
The exhaust will fit straight on, though if you have the toilet bowl style setup I'd advise you fit a 6 bolt flange setup. The MK3 airbox wont fit on the driver side chassis leg as its too wide, a cone filter would do the job but you need to make siure you have somewhere to but the air temp sensor if its a later one, if you get a 2e lump its no issue as you can just pop the cone filter on the end of the afm.
