scirocco parts fit golf?
(In Topic #81999)
getting a scirocco cheap mainly for the carb and inlet manifold to finish my 2litre conversion of to get it up and running.
but i need the steering rack and gear linkage for the gearbox, will the scirocco one fit? also i need a rad and fan, i heard people fit scirocco ones as they are top filld so you can sling the olf expansion tank in the bin for more room???
chears guys
p.s. seams a shame to break this scirocco as the body is more or less mint, bonnet laquer has liftd but apart from that its good, so if anyone wants the shell?? or bits?? (no bottom end as it knocks abit) but the rest is avalible????
simon
chears guys
simon
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
sim0n_parker
You have PM
Cheers Rob.
You have PM
Cheers Rob.
Black Cabbie
its a g reg so 1989 / 1990
<a href="
Scirroco parts are more and less the same as MK1 so you will be able to salvage loads of bits , rack the same etc
I thought the early ones had this set up , later used same as MK1 ?
Cheers………..
Cheers………..
cool, thanks guys!
either way with the radiator i will use it anyway as i have the 1300 rad so the pipes are on the other side so if its top fill then its a bonus if not then its not the end of the world.
chears again
simon
chears again
simon
<a href="
