Saying hi and first question
(In Topic #117318)
new to the forum, i have a 1982 4 door green diesel golf. bought it as a rolling shell, with plans to fit an 8v gti.
basically i have the engine, full wiring loom etc from a mk2. also have 3 mk2 8v gearboxes.
wht am i going to need to make it all fit?
dont have any drive shafts at all, so which ones do i need is my main concern right now.
thanks in advance
ross
i was under the impression that since i have the full wiring loom off a mk2 from this engine, i could chop that about to fit? then it would be a case of plugging and play with the engine bar the fuel tank/line problem?
if i was going to go the carb route, roughly what would i need?
Twin carbs need an inlet manifold, linkage, electronic fuel pump, fuel filter and pressure regulator. A GTI fuel pump relay would be needed to, along with the ECU, dizzy and associated parts from a carb model- either mk1 driver/cabrio of possibly a MK2 driver.
You can get most parts from Eurocarb or keep your eye out on e-bay for the bits you may need.
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
