Rad Question
(In Topic #145166)
Rad Question
What is the difference between the top fill rad and the rad with the header tank out the g60s mk2 16v ect as they are the same size in diameters so is there a better rad to use or is it a case of a decant fan and keep same rad which is the top fill one i have at the min??
JonP said
decent fan and a decent low temp switch on it
Low temp switch from what ?
JonP said
for the mk1, last i got had two temp settings on it.
lol i know what for i'm asking from what would you get the low temp switch or do you just ask for a low temp switch from vw ??
mine had options to run at 85 or 95
JonP said
you did ask from what though
Ahh right so you can get a low temp switch for a mk1 that fits the top fill rad
edit: doh!
nowt wrong with most slimline fans in themselves, just as i say slinging one on a rad by itself isnt going to work well. you need a shroud to make sure it pulls air thru the entire surface area
does the whole rad get hot? is it a single or double core? (how thick is it)
Not sure what rad he is using but it looks bigger than any mk1 rad :? Certainly keeps it cool anyway!
