painting my car flat black
(In Topic #81794)
![thatlukekid in the usergroup ‘Newbie’ thatlukekid in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
does it come in a tin or spray can?
where do i get it from?
help
![dicky_morris in the usergroup ‘Local’ dicky_morris in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
theres a guide on here for spraying and you should do the same regardless of whether its metalic/matt/ satin etc
basically your going to have to key the paint up by sanding it
then u gotta make sure that all the dust is removed, using tac rags etc…
you can buy matts and satins in can form and i would recommend putting them in warm water before spraying to get the temp up therefore increasing the pressure in the can…
also make sure u mask well!!
