overun cut off valve yes or no?
(In Topic #149156)
I have the isv and control box and am in the process of wiring it up, also the old wiring for the vacuum time switch in my 1990 cabrio is behind the battery do I just tape this up now? and not use it anymore.
Wheres the best place to take the +12volt supply for the 16 valve ecu from when doing this conversion? thanks
i think i wired the ecu to the coil
thanks. I was going to use the mk2 airbox but the size is much bigger so I would say the amount of cutting away involved wouls be silly, all advice greatly appreciated thanks again.
Also another question the metal water pipe from the pump to the heater rad is thicker than the 8 valve one, so the heater pipe is too small to go over it, does one just stretch the rubber heater pipe so as it will fit over the metal pipe or whats the best way to do it ??? thanks.
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Fproject-83-mk1-cabby
worst case just leave it off, you'll probably be ok without. keep the 2 pin plug in case you find it does cut out when lifting off at high rpm
